Old 12-11-2005, 09:04 AM
ken taylor ken taylor is offline
1994 S-10 blazer 4.3 4 wheel drive interior lights problem
having problem with my interior lgts .blows fuse #3 horn/ interior lgts
is there a module on the computer that could cause this all wiring looks ok. visional inspection
Old 12-11-2005, 11:14 PM
NoSpudsInIdaho NoSpudsInIdaho is offline
Re: 1994 S-10 blazer 4.3 4 wheel drive interior lights problem
I don't have a wiring diagram for the '94, but it's pretty safe to say that fuse has no connection to your computer - the horn and interior lights are ancilary items not monitored or controlled by the computer. A fuse blows because something in the circuit pulls an amperage greater than the limits of the fuse - in other words, there's some type of short in your system. Have you noticed if there is a particular event which causes the fuse to blow? There are a lot of different places a short can occur and linking to blown fuse to an event helps.
Old 12-12-2005, 03:30 PM
Re: Re: 1994 S-10 blazer 4.3 4 wheel drive interior lights problem
thanks for reply: interior lights used to dim after getting out of car ,a few seconds later . was thinking that maybe , controlled by computer.??
all dash lgts. are operational ash tray.
Old 12-13-2005, 02:18 PM
RahX RahX is offline
what size fuse is it? if its a 20 amp fuse check for something in the cig lighter, that is also on the same fuse. a lot of times a coin falls down there and causes trouble.
Old 12-13-2005, 03:36 PM
thanks no coins in lighter 20 amp fuse.
Old 12-13-2005, 03:53 PM
does it blow as soon as you put a new one in?
Old 12-13-2005, 04:01 PM
Is your rig equipped with a time delayed courtesy light? The dimming when you get out of the car would point to a problem with a conditional event circuit, on interior lights that would usually be a simple timer. The timers are generally triggered by the door being opened at then closed with no key in the ignition. Closing the door starts the timer and that's the time when you'd most likely see the effect from a short in that circuit. Does this seem to fit?
Old 12-13-2005, 09:24 PM
yes sir do you were it is located on truck. thanks for input. ken
