Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-11-2005, 08:09 AM
fastlife1 fastlife1 is offline
1997 Engine Rattle
Hi, I have a 1997 3.9L Dakota with 26K miles on it and the engine seems to have some sort of rattling noise. If you stand in front of the engine, it appears to be on the left side. The truck runs great otherwise. The rattle appears to be more noticable whe the car is in drive and even more when put into reverse. After a while the noise seems to either go away, or quite down a good bit. Any help or sugestions would be greatly appreciated. I tried to check the visual things and couldn't find anything too obvious.
Thx, fastlife1
Old 12-13-2005, 01:46 AM
Edward Ebbs Edward Ebbs is offline
Re: 1997 Engine Rattle
Probably a little late but did you check the catalytic converter?
When some of them go bad, they rattle...
Thx, fastlife1
Old 12-13-2005, 04:02 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Engine ping probably. Mine does it.
My Mopars
Old 12-13-2005, 12:59 PM
Tacuvito Tacuvito is offline
If it sound like a can rattle, it is your cat. It is very common. your cat might be loose or it might be worn and needs replacing. I've owned three dakotas and all have had this problem.
Old 12-15-2005, 09:18 PM
Engine Rattle
Thx for teh replies, I haven't checked the cat converter because the sound seemed to be coming more form the engine on the passenger side versus underneath the truck. I will definitely either try to check myself or get a muffler shop to check out the converter. I had read in another post that some others were having a similiar sound and they mentioned the timimg chain. Any thoughts?
Thx, fastlife
Old 12-15-2005, 09:23 PM
Engine Rattle
Thx for the replies, I haven't checked the cat converter because the sound seemed to be coming more form the engine on the passenger side versus underneath the truck. I will definitely either try to check myself or get a muffler shop to check out the converter. I had read in another post that some others were having a similiar sound and they mentioned the timimg chain. Any thoughts?
Thx, fastlife
Old 12-17-2005, 12:52 PM
inatalonIXLR8 inatalonIXLR8 is offline
I've got the exact same sound in the same place. As far as I can tell,and read, it's the timing chain. Please let me know if you're able to find what it is!
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
