Old 12-10-2005, 09:50 PM
newbicivic89 newbicivic89 is offline
Exhaust question
I was wondering it the exhaust from a 92 civic sedan would work on my 89 civic sedan they look the same. http://cgi.ebay.com/ebaymotors/ws/eB...tem=8020918108
Old 12-10-2005, 10:46 PM
justin476 justin476 is offline
Re: Exhaust question
I was looking for exhaust for my 4dr before i crashed it and i couldn't find very many. i don't THINK it will work..it is probably too long, but i don't know for sure. If i were you i'd just go to a muffler shop, buy like a magnaflow muffler and get the piping done custom. you'll save yourself a lot of money this way.
Old 12-10-2005, 11:29 PM
Re: Re: Exhaust question
How much will that custom piping cost to get it from the headers all the way to the back and a muffler Tip.
Old 12-11-2005, 12:06 AM
89si's Avatar
89si 89si is offline
check that out at some local shops
89si-
78000kms on original engine.
sub is in.. lights are just about done..
Old 12-11-2005, 11:54 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
If your in a small town that has a muffler shop, it don't cost a whole lot, but if you go to a big shop i don't know what they will charge for running from the Header back. It only cost me $50 to get mine done on my civic with 2 1/4" pipe, which is the biggest you wanna go unless your turbo. My friends Prelude has 2 1/2" on his and its too big, moved his power band to top end and lost a lot of his torque.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 12-11-2005, 12:32 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
as what happened in my hatch when i had 2.5 inch
but yea, go get custom done, its cheaper and better
the EG system is different, hangers are in different spots, they have one right over the rear flange where as our cars do not. and our muffler is under the trunk with the exhaust on the left side, EG exits on the right, so theres no where to mount the EG muffler unless u weld custom brackets etc etc
Old 12-11-2005, 03:50 PM
Re: Re: Re: Exhaust question
Well i will call around today and get some prices.
Old 12-11-2005, 04:57 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Tony
That is interesting about moving the power band to top end and losing torque.
I have been trying to tell them preformance people down in the blazer forum that they need to keep some back pressure on the exhaust system.
But the seem to think i am full of bull.
Good post and good info.
MT
MT
Old 12-12-2005, 06:04 PM
Tony's Avatar
TLD Member #1
Well its actually quite funny with my friends prelude...if he wants top end he runs without the silencer in, if he wants some of his torque back he leaves it in, and they are very noticable differences. Arguing with most domestic guys about that is a loosing battle. I live at a circle dirt track that runs a FWD class, most of them being rednecks around here, assume running with an open exhaust helps since it does on the v8s, the v8 can push enough it doesn't need that much back pressure, unlike 4 and 6 cylinders. So most of them in the FWD class run with the exhaust cut off after the drivers seat, only because its a rule. Once I get a car going im keeping my exhaust on there. The easiest way i win that arguement is when i swapped trannies on my 240sx, once i got it all hooked up, i did a test run without the exhaust...loud as hell...no torque, got the exhaust back on there and got my power back.
Tony
Old 12-12-2005, 06:39 PM
MT-2500's Avatar
AF - Advisor
Tony
Thanks for that info on it.
And 10-4 on them domestic performance guys.
MT
MT
Old 12-13-2005, 07:45 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
do u think putting in a regular cat not a high flow cat would help with back pressure on a 2.5" exhaust? since right now i have a gutted out cat and a resonator, would a new cat help me out?
The Evil Sleeper
Old 12-13-2005, 05:48 PM
Tony's Avatar
TLD Member #1
It could help, just go with a slightly smaller sized cat to create a little more backpressure and you should be fine.
Tony
Old 12-15-2005, 12:43 AM
I have an open muffler with a silencer aswell. Right now i have it off. So by putting it back on will i get more low end torque? or just more all around torque? I always thought that letting our cars breathe better will help hp gains like i/h/e thats why i got an open muffler in the first place..
Old 12-15-2005, 01:26 AM
fierangero's Avatar
fierangero fierangero is offline
Send a message via AIM to fierangero Send a message via MSN to fierangero Send a message via Yahoo to fierangero
you want some backpressure to facilitate scavenging, it keeps the exhaust velocity up, as well as keeping cold air from rushing back up there and cooking your valves (that only really happens on open headers). just keep in mind that the engine is much like an air pump, the faster air gets in and out, the more power is produced.
Rest In Peace, Rich Hall
my baby: 1986 Fiero GT: v6, automatic, 2.8L, 2.02/1.60 heads, Crane Performance Cam, Ported/polished exhaust manifolds, taylor plug wires, low temp thermostat and fan switch. WCF catback exhaust
She's done!
Old 12-15-2005, 06:10 PM
Tony's Avatar
TLD Member #1
Yea what he said. Putting a I/H/E on does help gain some extra HP, but opening it up too much without having enough HP to make up for it, hurts you in the end. Thats why with a turbo you will be fine running 3".
If you get a custom exhaust made and just have a high flow cat and a muffler, no resonators or anything, and feel like your not getting as much torque as you should be getting, get a resonator put in. Not to mention the resonator will quieten it down some too, no need to be getting the wrong type of attention. When I get a custom exhaust made for my 240, which will be soon because I just drug my factory exhaust off, I'm gonna leave the stock cat for now, atleast 1 resonator, maybe 2 if its too loud and then the muffler all having 2 1/4". I would go ahead and get 2 1/2", but no telling when I'll actually get around to swapping motors and getting a turbo.
Tony
