Old 12-10-2005, 07:49 PM
crazydriverz crazydriverz is offline
1.8 engine with oil leak.need some help
i notice some oil on the ground.so i jack up the car slide under the car and noticed oil to be leaking from a retangular plastic cover or door. i open it and i see the flywheel.could the oil pan gasket leak inside this plastic cover. or is the leak from something else.
Old 12-11-2005, 07:48 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
If you could see the flywheel then it's probably the rear main seal leaking or the input shaft seal on the transmission.
Nevada Tumbleweed
Old 12-11-2005, 10:55 AM
Re: 1.8 engine with oil leak.need some help
no it is not transmission fluid.its oil.its a plastic cover connected to the oil pan. im assuming it is the oil pan gasket.
Old 12-11-2005, 11:02 AM
Can't quite follow you since I have the 1.9L. but it sounds like you are talking about an inspection plate on the flywheel cover. There should not be oil in the same compartment as the flywheel.
Nevada Tumbleweed
