Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 12-10-2005, 05:50 PM
jasonnosaj jasonnosaj is offline
wont shift from park/no break lights/abs light!?
hi all,
ford e-250
start up, wont shift, abs lightsa' flashin'.
before i start i can unlock steering and shift into nuetral, start, then go into drive, abs lightsa' flashin'.
no break lights..
checked my break light switch with a ohm meter.. seems fine..
4 volts are going to it.. bridged the plug to the switch, no luck....
this has gotta be easy for guys......
what do you think?
[email protected]
Old 12-15-2005, 04:39 AM
KimMG KimMG is offline
AF - Advisor
Re: wont shift from park/no break lights/abs light!?
I would check to find out how many volts are suppose to go to the switch. 4 volts seems low. My car (different make) has 12 volts going to the brake light switch.
Old 12-18-2005, 11:34 AM
ModMech's Avatar
ModMech ModMech is offline
Corroded brake light fuse or connector. Find the FUSE, measure voltage on both sides, if 12V or more, problem is elsewhere. If under 12V on BOTH sides of fuse, problem is in power supply TO fuse block. If lower on one side than other, problem is corroded fuse/terminals.
You CAN run a new wire from battery to brake switch, just make SURE you fuse it.
Old 12-29-2007, 07:42 AM
Raymond Mcfadden Raymond Mcfadden is offline
Originally Posted by jasonnosaj
hi all,
ford e-250
no break lights..
what do you think?
[email protected]
I have the same problem with my f15 truck & my my abs fuse is blowing ..What did you do?
hi all,
ford e-250
no break lights..
what do you think?
[email protected]
I have the same problem with my f150truck & my my abs fuse is blowing ..What did you do?
