Go Back   Automotive Forums Car Chat > Volkswagen > Cabrio
Old 12-10-2005, 05:44 PM
Letni0231 Letni0231 is offline
Send a message via Yahoo to Letni0231
Angry How do I replace V-Belt on 99 Cabrio
What other bolts do I need to loosen/remove before the tensioner will walk upwards so I can release the belt? This is the smaller of the belts only running around 3 circles. Thanks
Old 12-14-2005, 10:20 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: How do I replace V-Belt on 99 Cabrio
power steering belt:
loosen 2 13mm nuts on pump to bracket (1 is inside a larger 22mm nut with star lookin thing on it)
use 22mm wrench to relieve tension on ps pump (turn clockwise looking at belt should move tward engine)
serp belt:
there is a special tool for this but you dont have it. i think a 14mm wrench can be used to loosen the tension enough to slip belt off.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
