Old 12-10-2005, 03:06 PM
cbailey cbailey is offline
spark knocks
Hello again everyone,
My dad has a 2000 windstar with a 3.8 and has a problem with it spark knocking. He has had the ford place check the timming and everything else on it and they say that every thing is ok, but I know he's not crazy because I have heard it myself. The van has around 60,000 miles on it , give or take a few. I was wondering if anyone has had the same problem and if so how or what can be done to solve it.
Old 12-10-2005, 03:18 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: spark knocks
Check the EGR system for egr valve working and also the egr valve ports in the intake to each cylinder.
And do not forget to check the dpfe sensor.
It starts the process to open the egr valve when needed.
MT
Some were even recalled.
Run the vin at tour ford dealer for recalls.
MT
Old 12-10-2005, 03:34 PM
phil-l phil-l is offline
Re: Re: spark knocks
My 2000 Windstar LX 3.8 made similar knocking sounds. At first, I blamed it on gas from a particular station, but the sound got worse over time. I had no CEL, as some people do.
After a lot of reading on this web site, I decided the likely culprit was the infamous isolator bolt problem. I performed the leckemby.net procedure that's widely reference on this board: the knocking disappeared.
I'l also note that my DPFE failed about a month later, but that was an easy fix.
Both items are very common on 2000 3.8 Windstars at the 70K mile mark.
Old 12-10-2005, 05:08 PM
12Ounce 12Ounce is offline
Re: spark knocks
I agree with phil-l, in the early stages of failure ... before codes are thrown ... the loosening isolator bolts (and plugged EGR jets) can cause pre-ignition-like knocking.
Old 12-10-2005, 05:33 PM
wiswind wiswind is offline
Re: spark knocks
The isolator bolt TSB is fully explained at
http://leckemby.net/windstar/windstar01.html
