Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-10-2005, 12:37 PM
gunterstan69 gunterstan69 is offline
96 contour v6 giving codes
I'm wanting help trying to figure out what is wrong wiht my car this started last sat. my gf went out to start the car and it would start but then die right away it was really cold that night so I tried it later that morning runs fine on the highway but you get stoped and it surges, I have replaced the spark plugs, iac valve, iat sensor and tp sensor but it still is running funny only codes that have pulled are 113 that was befor I relplaced the iat sensor, now the codes are p0171 and p0174, could anyone please let me know anything that could be causing this problem
thanks
Old 12-10-2005, 04:09 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 96 contour v6 giving codes
thanks
Your getting 2 lean codes, one for each bank. I would inspect for vacuum leaks first. That would give the exact problems that your describing. If you can't find any vacuum leaks, trying cleaning the maf wires as described on the how-to on contour.org.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
