Blower motor switch
Does anyone know where I could buy a blower motor switch for a 99 wrangler? My current switch only works on settings 4 and 1. Also when I switch it to speed 1 but go a little bit too far to the left of it the fans blow at speed 4. The current part says 9918 on it if that helps. I've been looking online and haven't been able to find this part anywhere. Any help would be appreciated.
Re: Blower motor switch
Probably not the switch but the resistor pack.
Two of the resistor tracks are probalby damaged by heat. On my 02, it's located under/below the glove compartment. You can access it from below but I found it easier to remove the glove compartment as well. The unit is mounted in the air plenum (for cooling). Two screws hold it in place. About 2.5"x1" Square with rounded corners. A new one cost me 25$ CDN. |
