Old 12-10-2005, 10:02 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
boosted l98
could an l98 take about 6 or 7 pounds of boost and still be reliable?
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 12-10-2005, 10:28 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: boosted l98
u mean like blowing head gaskets and burning valves? It will be if you get a super thick quality gaskets for it ($600 each), similar to what 600hp civics use. Defenatly you need a healthy motor, rebuilt head, good head gaskets, a remote turbo, 5-6 psi and you will be nice and reliable (very common on mustangs)
I say go for it. I would get some used garett turbo and maybe rebuild it and than just weld all pipes in a shop with no cats and mufflers. Should be pretty cheap.
Old 12-11-2005, 12:06 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
6psi of boost is very much managable in a stock l98... i forget what show it was but they put a centrifical supercharger on an l98, and it was pushin out about 6psi or so, and handled it fine...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 12-11-2005, 02:39 AM
Re: boosted l98
cool. I just picked up a paxton supercharger kit. Its supposed to make about 5-7 lbs. of boost so thats why I ask. Should be pretty cool.
Old 12-11-2005, 02:44 AM
Banned
Re: boosted l98
how much? and what kit
Old 12-11-2005, 02:46 AM
Banned
Re: boosted l98
i like the remote type bcause its a lot easier. No pulleys and belt, no mounting plate, no inter -cooler, less heat, less exhaust.
Old 12-11-2005, 09:09 AM
Re: boosted l98
Its an sn-93 kit for 88-92 camaros that im getting from a guy selling it on thirdgen.org. Hes going to a BBC setup and doesnt need it anymore. Hopefully the deal goes through just fine and I will be ready to go in a few weeks.
I was looking at those remote types. Looks cool. Id like to see one in a car.
