Old 12-10-2005, 08:17 AM
cleanshavenrsx cleanshavenrsx is offline
Send a message via AIM to cleanshavenrsx Send a message via MSN to cleanshavenrsx
::95 Blazer:: Cooling system flush
i have a 95 blazer with orange sh|t in the over flow... is thatr dex cool? can i flush it and put in regular antifreeze
What Flush should i use???
What coolant should i use and why???
o and it was low is it ok i threw in some water??
Old 12-10-2005, 10:03 AM
Eslhockey92g's Avatar
Eslhockey92g Eslhockey92g is offline
Re: ::95 Blazer:: Cooling system flush
http://www.automotiveforums.com/vbul...t+system+flush
Old 12-10-2005, 01:48 PM
i love forums i get the exact knowledge i need
Old 12-10-2005, 03:13 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If you want to recieve info you have to give some info.
If it is leaking find the leak.
If it came out with dexcool put dexcool back in it.
Only problem with dexcool is it does not last as long as the manf. says.
Replace/flush it every 3 years or 50K and you will not have any problems with it.
MT
MT
Old 12-10-2005, 10:01 PM
Re: Re: ::95 Blazer:: Cooling system flush
MT
nothing wrong but an air buble but i just bought it i know nothing bout it so im doing everything
Old 12-11-2005, 03:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Re: ::95 Blazer:: Cooling system flush
Ok, I have a couple tips for you.
1.) Completely flush out the overflow tank, the stuff coming out of mine was absolute brown snot. It was really alarming what was in it. This was residue left over from when the stock rad cap was on.
2.) Use Dexcool again, no need to change.
3.) I used two bottles of system flush. Clean once, rinse, clean again, rinse,,,then rinse the system out completely until only clear water comes out and then dump the rad water and start filling it with straight coolant and the system will fix the coolant for you.
Be patient and allow the thermostat to open so the cleaning works well.
4.) Replace the rad cap with a Stant, get rid of the stock AC Delco junk.
5.) Be patient, it took me over 2 hours to flush my system out. when you include all the flushing and rinsing.
6.) Go to the dealer and buy two of the GM cooling system sealer tabs and add it to the rad when you are refilling it with straight coolant. The tabs will have to be crushed and you add the fine poweder to your coolant to seal any small leaks in your gaskets. Worked great for mine.
Any other problems, just knock and we will help you.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-12-2005, 01:24 PM
thanks man great info
Old 12-12-2005, 05:38 PM
blazee's Avatar
blazee blazee is offline
Problem?
GM doesn't recommend using the sealing tabs anymore, because they can contaminate the dexcool.
Old 12-12-2005, 05:50 PM
BlazerLT's Avatar
AF -Advisor
Where is this said? I got these straight from the dealer and they said that they were completely fine to use.
Old 12-12-2005, 05:55 PM
blazee's Avatar
Problem?
Page 2 "Sealing Tabs"
Old 12-12-2005, 06:05 PM
BlazerLT's Avatar
AF -Advisor
Well, when I changed my coolant I had a small leak that occured in the intake gasket when I flushed the system and this sealed it right back up. Works great.
A lot of shops still use it as long as you don't overboard on the dose, you will be fine.
Just adding what I did.
