I,m having problems maintaining a good temperature during summer months. If anyone has any Ideas I welcome them
Re: engine cooling
to hot or to cold?
Re: Re: engine cooling
Re: engine cooling
could be a blowen hed gasket/cracked head... could also be time for a coolent flush,,, whens the last time it was done? and finally it could be a water pump... what year truck are we talken??
Re: engine cooling
Check your water pump, thermostat, radiator and rad cap.
And, as mentioned by dmbrisket, a coolant flush is recommended.
Re: engine cooling
Thank you all for the replies but I've put in a new water pump, (which I found to be particularly easy) new thermostat, new head, new transmission filter and fluid, the only thing I havent done is flush the system. Its a 1995 with a 2.2 and I'm thinking maybe a sensor isnt working right or its something electronic
Re: engine cooling
I had a clogged radiator once,someone put stop leak in and gummed up the radiator. I found that is was so clogged, I couldnt get a good flow. I had opened the spigot, and filled the rad, and it just dribbled out the spigot.
Daily Driver: 2008 Chevy Impala - 30000 mi Others:1993 Chevy S10 - 85000 mi, 2000 Saturn SL2, 1987 Buick Lesabre RIP, 1999 Buick Lesabre |
Re: Re: Re: engine cooling
I am brand NEW to the list and have a ?.
2001 suburban 5.3lt 4X4. There is a coolant leak from the lower front left (driver side). It looks like it is from a plug. Is this the block drain? How is it repaired? Robert |
Re: engine cooling
well airbus, next time start a thread for your question, youll get more help that way... and it is most likly a core plug (freeze plug) or a block drain...
I am thinking it is a block drain. Is This EASY to replace. How do I remove the existing plug? I am having little problem figuring out how to start a new thread, but I will figure it out. Robert
Re: engine cooling
fairly easy, it either takes a 4 or 8 point socket on it, or a 3/8 drive into it... to start a thread, in the main 's 10' part, theres a button that says 'start thread' or 'new threa' something along those lines... click it and there ya go
