Old 12-09-2005, 06:49 PM
newbicivic89 newbicivic89 is offline
engine problems
Ok when i crank my car up it like revs itself up then it will idle back down very low then back up then the check engine light comes on and then it will run just perfect. It will also make this poping noise then i rev it up to about 5K and it will stopp.And also my car smokes bad really bad i changed the oil in it and still have the same problem. Help would be very good.
Old 12-09-2005, 08:50 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: engine problems
Pull the check engine light code and find out what it is.
Old 12-09-2005, 08:54 PM
Re: Re: engine problems
You lost me. I dont understand what your saying explain more please
Old 12-09-2005, 09:15 PM
arodg25's Avatar
arodg25 arodg25 is offline
Re: engine problems
with the car running, look under the carpet where the passenger would put there feet and there should be a light blinking, count how many times. it will blink up to a # then pause for a sec and repeat. look here http://www.automotiveforums.com/vbul...d.php?t=118785 (the 5th post down) to find out what the code means
Old 12-09-2005, 09:40 PM
Ok thanks it blinked 3 times which means Manifold Absolute Pressure and dose that mean that tthe manifold needs to be tightend more to the head or what.
Old 12-09-2005, 10:03 PM
WDELOAD WDELOAD is offline
Re: Re: Re: engine problems
no u need to buy a new one..
Old 12-09-2005, 10:13 PM
CivicSpoon's Avatar
There is no Spoon
Re: engine problems
It's your MAP sensor, not the manifold.
Edit: http://www.crxpower.net/~silverkorn/...hop_Manual.pdf Go to page 133, and get a volt meter.
Re: Re: Re: Re: engine problems
No other alternatives
Old 12-09-2005, 10:18 PM
Re: Re: Re: Re: Re: engine problems
Also would that cause your car to overheat.
Old 12-10-2005, 07:52 AM
Re: Re: Re: Re: Re: Re: engine problems
Where is the HAZARD Fuse Located at.
Old 12-10-2005, 08:02 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: engine problems
in fuse box on passenger side wheel wall....big black box hazard fuse will be labled
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 12-10-2005, 08:19 AM
Also if i decied to swap my stock d15b2 engine with a d16y7 non-vetch what would I have to do.
Old 12-10-2005, 12:48 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: engine problems
convert to MPFI and rewire for it, get a new distributor with the correct sensor, get a new ECU, drop engine in.
Old 12-10-2005, 01:23 PM
Where could i buy a MPFI conversion kit for my car and a new distributor.
Old 12-10-2005, 02:24 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: engine problems
does the d16y7 come with a distributor?
there are no mpfi conversion kits out there, you gotta make your own
you basically need:
mpfi intake mani complete injectors, fuel rail, tb
mpfi distributor
resistor box if going obd0
mpfi ecu
having a wiring harness for whatever obd you are goign to put in there really helps.
with on that list i put above does the y7 come with any of those things already?
Team Lonely Drivers
