Old 12-09-2005, 03:53 PM
sblkcamaro70 sblkcamaro70 is offline
turbo a d15b2
when turboing a d15b2 how much psi can it take safly for a daily driver?
Old 12-09-2005, 03:58 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: turbo a d15b2
i wouldnt go higher than 150whp. dont try and boost on the dpfi system, gotta go mpfi.
Team Lonely Drivers
Old 12-09-2005, 04:16 PM
duffman868 duffman868 is offline
Re: turbo a d15b2
i dont even think 150 would be safe for a dd unless it was a realy good tune. the rods are the size of a sharpie. but do it then once it blows throw in a z6 and run almost 200 daily
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 12-09-2005, 04:45 PM
Re: turbo a d15b2
it could be, it could not be. whos knows. thats why i said use 150 as a max. me personally i would probably go for 130 or 140whp. depending on turbo size it would probably be 6 or 7 psi
Team Lonely Drivers
Old 12-09-2005, 07:02 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: turbo a d15b2
damn..thats sad, lol 130 hp turbo honda... just swap in a d16z6 and have 128hp and not worrie about it. 300 will get you a z6 motor add another 100 with a tranny, you can run it obd1 with the p28, or use a pm6 with a vtec switch. than you save money and turbo the z6 ...if you want...just my opnion
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 12-09-2005, 07:35 PM
newbicivic89 newbicivic89 is offline
Re: Re: turbo a d15b2
Where can you buy a z6 for 300 and a tranny for 100.
Old 12-09-2005, 08:41 PM
arodg25's Avatar
arodg25 arodg25 is offline
i think hes talking wheel HP you'd be lucky to get 100 Whp from a stock z6 and not to mention the torque from a turbo would be a lot higher than the z6 also.
Old 12-11-2005, 01:51 AM
i am doing this so the d15b2 can pull the tall gears of the hf tranny i put in. i was reading homemadeturbo.com and they said a probe turbo will work but i was wondering if that would be good for a daily driver. any other suggestions on turbo set ups from other cars. i am doing this just to putts around and have fun you know tinker.
Old 12-11-2005, 04:37 AM
Re: turbo a d15b2
pretty much any car that came turbo is a good turbo
Team Lonely Drivers
Old 12-11-2005, 11:07 AM
right but as far as how mcuh wil the d15 handle as far as psi
Old 12-11-2005, 02:21 PM
Re: turbo a d15b2
dont look at it as psi because different turbos put out different hp at different psi.
you want to look at it as how much hp do you want.
Team Lonely Drivers
Old 12-12-2005, 12:09 AM
i am not looking for horse power numbers. i am looking for reliability. i just would kind of like to know what max psi a d15b2 can run at. (this car is for economical and relability only. if you saw it you would say ooo yeah hes right.
Old 12-12-2005, 01:23 AM
would 7 psi be ok for the d15b2 or will that be too much and screw something up?
Old 12-12-2005, 01:39 AM
CrxFreak91 CrxFreak91 is offline
Re: turbo a d15b2
5-7 psi would be good just run an intercooler anyways it will help. that will be safe and you still can have fun
Old 12-12-2005, 02:31 AM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
5-7 psi will give u prolly around 35-55hp gain to the crank on a b2.. but what id be worried about is getting enough fuel.. im not sure if u can upgrade any1 of those (2) injectors or not.. something to look into if ur intrested.. if i were u id definately would do a mpfi conversion first.
