Old 12-09-2005, 04:24 PM
directory's Avatar
directory directory is offline
is it wired for a v8?
1992 firebird convertible 3.1 ltr v6
i want to put my 1991 chevy caprice (police package) 350 v8 in it.
i was poking around under the hood. i see the holes for a v8 motor mount and several other plugs just hanging around, not being used on the wiring harness. is it possible that the harness used is a generic one that would accompany both a v8 engine and a v6, depending on which one is installed-- per package details.
i have the original wire harness out of the caprice--w/ computer, etc--100% complete. but it would be nice just to have to unplug the old computer and engine--to plug in the new stuff.
am i feeling lucky?
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 12-09-2005, 06:22 PM
CreepingDeath94 CreepingDeath94 is offline
I doubt it, it is probably just for other options/accessories that the V6 could be equipped with. However, since you have the other harness there, compare the two and see if they look the same under the hood compared to whats in there just hanging around.
Old 12-09-2005, 07:39 PM
directory's Avatar
Re: is it wired for a v8?
good idea...
i was hoping that i could bypass the ripping it out of the car phase of things. ow well...where are my tools...
SKYWARN
we be clubbin'
--B
Old 12-10-2005, 12:17 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Complete different computers, and complete different harness'. Would require a ton of work to do the swap. The engine will fit into the Firebird fine, but you're talking about alot more than just a basic engine swap. You would need a ton of other upgrades on the body as well.. which happens to be a pretty hefty list that I'm really too lazy to type out at the moment. Plus, I can't really think of then all off the top of my head. I think www.thirgen.org has alot of info on it. Not sure if the tranny out of the Caprice will fit into the Firebird either. Best to do some research on it, unless you get lucky and someone comes along who knows all the details on the swap. But all I can tell ya is that the 350 will fit fine in the Firebird, but you would need to swap out the wiring harness' and computer as well. Good luck with it and hope you can find some more info.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 12-10-2005, 12:24 AM
Most people who do the V8 swap install a carburated engine, or they are just swapping the 305 for the 350 which is an easy swap.
Old 12-10-2005, 04:31 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
the 350 should fit...for a little while, the 3.1L tranny will be able to handle the power of it..until it blows! hahaha
Old 12-13-2005, 09:42 AM
Underground_Killah's Avatar
Underground_Killah Underground_Killah is offline
Registered User
i'm about to buy a 94 v6 firebird. will the lt1 swap with no problems?
i'd like to know before hopefully tomorrow when i go test drive it.
Old 12-13-2005, 11:17 AM
tuske427 tuske427 is offline
Send a message via AIM to tuske427
rule of thumb- the newer the car, the more complicated the swap. This is because the sophistication and complexity of wiring and computer controls/ sensors, etc increases with the newer cars. (It's not impossible, it just gets more complicated, espeically if you don't know what you're doing)
If you're considering a 4th gen car. get the V-8 model. Spend the extra 2 grand upfront and save it later on and more, plus headaches and time later on by buying it up front.
and get the 6 speed while you're at it. If you're going to get an LT1 car, I reccomend a '95 or newer. They have the vented optispark distributor, plus, with the Trans Am you don't have to worry about finding a "GT" model (1994 only) to get the 155 mph speedometer, T/A spoiler and a few otherwise standard details.
The 1993 models had a "speed density" system that isn't as receptive to performance gains as the '94 and newer "mass air flow". Avoid it if you can.
Again, these earlier cars aren't impossible, but it's one more hurdle/ expense you can avoid upfront by careful shopping.
Good luck!
Long live the muscle car
Old 12-13-2005, 12:54 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
you guys are not gonna believe this but my friend's friend had a trans-am 95 or something l guess. he put V12 on his car. l swear. l didnt know the guy l just saw the car. and he had an accident 2 weeks ago. and his reasion was that his brakes werent as good asnormal because nof v12 engine. engine was too heavy and his car couldnt stop. and he passed the red light and hit maybe 6 cars.
can u believe this guys.. V-12 engine on a trans-am.. woohhooo
Old 12-13-2005, 03:05 PM
Registered User
well i was thinking i could pick up the speedometer from a salvage mart here or something because i know the higher speeds were on the 95+ models and i think they should fit no problem in the 94 cluster.
I was just curious if the lt1 would bolt in fine because it's hard to find firebirds here for sale for the price i'm being offered (2k)
