Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-09-2005, 03:14 PM
carmel 9 carmel 9 is offline
Question 1994 Mercury Grand Marquis
I have a couple of questions. First question air bag light is blinking what is wrong? Second question what is wrong when you rev the engine and alot of smoke comes out of the tailpipe? Third question what is wrong when I park my car on a hill with the front facing down hill and oil leaks out? What is wrong when the car keeps cutting off? I have put alot of money into this car and it seems like I am getting one problem after another. Please!!! I am in desperate need of help can anyone help me with these problems.
Old 12-11-2005, 04:47 PM
Unhappy Help !!!
Can someone help me with my questions come on somebody help !!!!!
Old 12-11-2005, 07:05 PM
SiZzOuRcE SiZzOuRcE is offline
Re: 1994 Mercury Grand Marquis
Count how many times your air bag light blinks first off. It will be in segments like ''''' '' ''''' '' ''''' ''. In segments.
Second, what color smoke is coming from the exhaust, if its blueish/white then its oil. That could be many things, my 94 Grand Marquis smokes like a biatch also, but there is nothing wrong with it.
Thirdy, I have no idea about the other problems. Once you've counted the segments of the blinking air bag light, find a site that has codes and find out what that code means.
Example: ````` `` = code 52
Old 12-12-2005, 12:30 PM
Re: Re: 1994 Mercury Grand Marquis
I checked the code and it reads 51. What do I need to do about that. The smoke coming out of the tail pipe it looks white. What does this mean. I hope its not a big problem.
Old 12-12-2005, 12:37 PM
Question I found the what the code means
It says diagnostic monitor thermal fuse- blown and short to ground no longer exists.
Old 12-12-2005, 09:23 PM
My code still blinks 52 or 51, I forget. Either way it means that your airbags will not deploy on impact. For me it meant that I needed to replace a computer that was $200 I think at autozone and something else. The smoke is normal, get a tune up soon tho, that might help out with the smoke.
Old 12-15-2005, 01:22 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Does the oil only leak when its parked on a hill?....It could be several areas..the pan gasket, the filter may not be quite tight enough, or even the sending unit could leak. I doubt if it's the drain plug, because you said it leaks when facing downward and the plug would be facing up in that case. Clean the bottom of the engine and park on the hill again. Then look underneath again, you should be able to pin point the source of the leak easier that way.
White smoke could be from leaking valve guides. Does your car use up a lot of oil before an oil change is due? I agree that a tune up may help fix this problem
Old 12-15-2005, 10:42 AM
Thanks for your help I took it to dealer just because it was the air bag I wanted to make sure that if anything went wrong I could blame them not myself. I was right about the part and it costed 246.12 and my labor was 270.00 it really was a waste of my time because it was something I could have put on myself. You may want to check your relay fuses too. I will try and get a tune up soon I think its about that time. So If you ever need to pass inspection due to your air bag light you will Know what to do.
Old 12-15-2005, 11:22 AM
The car only leaks when its on a hill. what is the sending unit? Right now there isn't any oil leaking and I think its because its to cold. I think the smoke is white. does that mean I need a valve cover gasket and if I do whats the price range of that sometimes when I check the dipstick it will almost be dry and then I started adding oil when I think it was low. Now I have to much oil. maybe I'm using the wrong oil I was using 5w 30 but jiffy lube told me that 5w 30 was to thin for my car and my car burns it fast so I changed it to 10w 30 castrol oil. I'm going to get a tune up soon.
Old 12-15-2005, 12:23 PM
Loekee75's Avatar
Re: Re: Re: 1994 Mercury Grand Marquis
The oil sending unit tells the gauge how much pressure you have...some cars have this sensor screwed into the oil pan, and road vibration will cause it to leak a little. A small twist of a wrench will fix the leak.
Your valve cover gasket may be fine, the valve guides are inside of the covers, surrounding the valves themselves. How many miles does your gm have?
Old 12-15-2005, 05:31 PM
Re: Re: Re: Re: 1994 Mercury Grand Marquis
It has 139,000 miles I just replaced the transmission last year.
Old 12-28-2005, 11:41 PM
babyivan babyivan is offline
Re: Re: Re: Re: Re: 1994 Mercury Grand Marquis
After about 100k, the 4.6 V8's usually start to consume oil.
It's really not a big deal though, just make sure you keep an eye on the oil level and add when necessary.
My 92 MGM has started burning oil at about 90k.
2005 Lesabre Custom w/41K miles
Old 12-29-2005, 02:31 PM
Re: Re: Re: Re: Re: Re: 1994 Mercury Grand Marquis
That's a nice car looks a little like mines.
It doesn't leak on flat level but my driveway is a slanted hill like drive way and the oil leaks all out. I don't know what to do about it any more. It failed inspection for smoking and I think they are over exaggerating because it was like a little puff of smoke. I have taken it to the dealer and they have no answers so I have reported them to the better business bureau because I have taken my car to them on seven different occasion and this is were I'm at now.
Old 12-30-2005, 02:55 AM
there's a rubber gasket type thing that connects between the engine and the oil filter...they tend to go bad as well. That might be the cause of the oil leak.
It's a relatively simple thing to fix.
Old 12-31-2005, 09:01 AM
Do you know whats the name of the part or the place were you need to put it. Maybe that will help the oil from leaking.
