Go Back   Automotive Forums Car Chat > Saab > 900
Old 12-09-2005, 01:20 PM
Stoeger Stoeger is offline
Slow to Start ... Fuel Pressure Regulator?
96 900S 2.3 4 cyl, 100K. Always starts, but it cranks for like 6 seconds before it finally fires. Once running, it's great. Replaced starter, fuel filter, cleaned IAC, new plugs, new wires.... what could it be?
Fuel Pump ?
How do I test fuel pressure at home?
Old 05-15-2006, 03:55 AM
adept-I adept-I is offline
Re: Slow to Start ... Fuel Pressure Regulator?
You have a distributor, or distributorless ignition system ? If distributor..., check/clean the cap, points gapping and change the rotor button; If distributorless..., change out the DI cassette and see if either of these solve your problem.
One other suggestion would be to pull the crank postion sensor and clean it, then replace.
