Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 12-09-2005, 12:28 PM
khieb11 khieb11 is offline
Send a message via Yahoo to khieb11
fule , temp guage
I have an 87 bronco II the fule gauge and temp guage went out at the same time I'v checked all fuses in the fuse box they all are good dose someone know what might be wrong? have I over looked something
Old 12-10-2005, 01:07 AM
Truck Truck is offline
Re: fule , temp guage
Temp gauge runs off of a small sensor that hooks onto the right (Driver's) side of your engine. Maybe you disconnected it. Look for a small, rubber boot with a 90-degree angle in it. Make sure nothing's dangling. As far as your Fuel Gauge goes, that could be a problem in your tank. Do you want to tknow about it?
Old 12-10-2005, 01:20 AM
Angry Re: Re: fule , temp guage
the thing is the other day i was driveing it and i shut it off at the store and when i started it back up both the fule and temp gauges quit working ,i'v checked the temp wire and under the tank to make sure all were still connected and the were ,is there a fuse that is hiden some where that is hard ti find that works them both?
Old 01-14-2006, 11:04 AM
Dot10 Dot10 is offline
Re: Re: Re: fule , temp guage
I have the same problem. Both fuel guage and temp indicator are inop. I've checked all fuses as well, even though none are labeled to have anything to do with fuel or temp guages. Wiring seems OK. Anyone have any ideas?
Old 01-15-2006, 06:52 PM
gbic1 gbic1 is offline
Sounds like a bad gauge. Had this problem with full size bronco back in the 80s was common.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
