Old 12-09-2005, 12:20 PM
jsharpe jsharpe is offline
99 Ford Windstar -Sliding Door Problem
The doors seem to have a roller that must be missing or flat because it takes a significant amount of effort to open and close either side door. Any ideas and should I tackle the repair or should I take it in?
Thanks, Jim
Old 12-09-2005, 03:12 PM
baumbr baumbr is offline
Re: 99 Ford Windstar -Sliding Door Problem
First things first, have you cleaned and lubricated all the moving parts? From your profile dust and dirt won't be a big problem, but the humidity in your part of the country can create a really nice sticky goo on rollers, axles, cams, etc. in the door mechanism. Good luck.
Old 12-09-2005, 04:00 PM
Re: Re: 99 Ford Windstar -Sliding Door Problem
Any suggestions on type of cleaning agents to use....mineral spirits? I will assume that the same grease I use in my home garage door would fit the bill for lubrication! Thanks, Jim
Old 12-11-2005, 08:41 AM
sodadude sodadude is offline
I Had A Similar Problem
Turned out the battery was getting old and tired, not unlike myself, and installing a fresh battery helped correct the sliding door problem.
Just a thought.
