Old 12-09-2005, 11:59 AM
tcfco2005 tcfco2005 is offline
shifter vibrating in upper rpm's
For some reason when im driving fast and my car hits the upper rpm's i start getting this vibrating noise coming from my shifter...i still have the stock auto shifter. and although i have a new tranny in there it was still doing it before but now its worse...any suggestions?
1991 RS
305 T.B.I.
700-R4
Old 12-09-2005, 12:03 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: shifter vibrating in upper rpm's
did you change the tranny mount with the new trans?
Old 12-09-2005, 12:04 PM
ya its a poly too...could that be why
1991 RS
305 T.B.I.
700-R4
Old 12-09-2005, 01:15 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
polys are stiffer and therefore cause more vibrations. I m trying to think, mine might rattle but idk
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 12-09-2005, 01:56 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Are you sure the drive shaft weight is there?
Old 12-09-2005, 02:12 PM
ya it was there when i put it up there...ill get under there again and check...i got to get under there anyways to adjust my torque arm
1991 RS
305 T.B.I.
700-R4
Old 12-09-2005, 03:18 PM
wrightz28's Avatar
ok, but you need to spot match the location, kinda like balancing a tire. So, when yuo remove a drive shaft, you need to mark the yoke ends and the out put shaft and diff so your still in balance when you put it all back together.
Old 12-09-2005, 04:43 PM
so how do i do it now that i took it off and put it back on without marking it...
1991 RS
305 T.B.I.
700-R4
Old 12-10-2005, 09:07 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
aluminum ones dont have those little weight on them do they? You could just pick up one of those... I dont know where you could go to have your driveshaft balanced
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 12-10-2005, 09:23 AM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
you could always spring for a new one while your at it... get a nice aluminum driveshaft from FormulaLT1 for cheap...
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 12-10-2005, 10:56 AM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
i want one, where has he been?
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 12-10-2005, 11:46 AM
Re: Re: shifter vibrating in upper rpm's
probably strokin the shaft lol
Old 12-10-2005, 02:30 PM
i already have an aluminum driveshaft that is balanced...it came strait off a 01 ss
1991 RS
305 T.B.I.
700-R4
Old 12-10-2005, 05:34 PM
and thats the one thats on your car right now?
Old 12-11-2005, 01:56 AM
ya...
1991 RS
305 T.B.I.
700-R4
