Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-09-2005, 11:16 AM
jberenyi jberenyi is offline
Unhappy 99 Suburban Interior Rattle...HELP
My 99 Suburban is bugging the crap out of me so I hope someone can help. Everytime I drive it on bumpy road conditions which is often around here, I hear a rattle coming from the corner of my driver side door right near my head. I feel around, touch, check everything and nothing. I even got outside the vehicle to check the door alignment and see if there is interference with the door and frame...nothing. It is so bizzare. It's almost as if something is rattling between the headliner and roof in the corner of my driver's side door. I even checked the roof rack and there is no movement there either. BTW, when the sound is happening it actually sound like a loose door but the hinges are tight. I grabbed the door and pulled up and down and there is very little movement. Can someone help with this weird problem. I'm ready to take it to the dealer but would like to avoid it...$$$$. Thanks in advance.
Old 12-09-2005, 06:32 PM
sundancer88 sundancer88 is offline
I had a rattle that I though was interior, but ended up being the louvered black plastic by the windshield wipers outside. I looked everywhere for it and for months I too thought it was hinge related. Hope this helps
Old 12-15-2005, 02:50 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: 99 Suburban Interior Rattle...HELP
Try removing the rubber molding that holds the headliner up, around where that noise is coming from. Now gently pull down on the headliner and you might be surprised,...some ...I'll call it "foreign object" may be stuck between the headliner and roof.
Old 12-16-2005, 11:31 AM
mitch2264 mitch2264 is offline
My '99 is bad about not fully retracting the seat belts and the metal buckle will vibrate against the plastic on the pillar posts. I hope yours is something as simple as that
Good luck! I hate rattles!!!!
