Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 12-09-2005, 08:21 AM
Greg Gore Greg Gore is offline
Question:Oil Drain Plug MM Wrench Size?
Can anyone advise me what the wrench size is for the oil drain plug in a 2003 Chevrolet Venture van with 3.4 engine? I need to get the right metric wrench or socket.
Thanks, Greg
Old 12-09-2005, 09:36 AM
bleepster bleepster is offline
Re: Question:Oil Drain Plug MM Wrench Size?
13 or 14 MM (cant remember)
Old 12-09-2005, 10:16 AM
2003 4.3L GM Drain Plug Size?
I recently purchased the 2003 Venture van with 15K miles as a bank repossession. I will be flying out Monday to go pick it up and wanted to change the oil and filter and put Mobil-1 in before heading back home on the 1250 mile trip. I am not familiar with the size tools I will need to take with me on the airplane and wanted to take only what I actually need. I bought a PF-47 oil filter today to see what I need for an oil filter wrench and I have a Snap-On YA-995 3/8" drive cup style wrench that fits the filter. If anyone familiar with changing oil on a 3.4L Venture could give me some tips on what to expect I would be grateful for it; I will be doing this myself in the parking lot. Can you advise if the oil filter and drain plug is easily accessible from underneath? Are there any plastic debris shields that have to be removed for access? For the filter will I need a 3/8 extension between the ratchet and cup wrench or would the usual small band type wrench with a handle work better. Is this a simple job with everything easy to get to?
Thanks, Greg
Old 12-09-2005, 10:25 AM
cdru's Avatar
cdru cdru is offline
It should be a 13MM wrench, but take a pair of pliars or an adjustable wrench in case the plug as been mangled (like mine was) or been replaced by a different sized one.
The filter can be changed on the ground, but it's hard without some ramps to drive it up on. It will also usually a messy job due to where the filter is positioned.
Why don't you just take it to a Quick Lube type place and give them the materials. $20+materials would beat doing an oil change in a parking lot anyday. Plus doing it there you don't have to worry about catching and disposing of the old oil.
Vinyl adds horsepower, right?
Old 12-09-2005, 10:35 AM
jhong1226's Avatar
jhong1226 jhong1226 is offline
15 mm
Old 12-09-2005, 11:28 AM
gkindub gkindub is offline
CDRU is right. Removing the oil filter will result in a major oil spill. PS: Working under the hood or underneath the U-platform vans is never as simple as you might think. About the only hassle-free job on these vans is changing the PCV valve.
Old 12-09-2005, 12:07 PM
cdru's Avatar
Re: Re: Question:Oil Drain Plug MM Wrench Size?
Originally Posted by jhong1226
15 mm
I could have swore on mine it was a 13 because I always think it should be larger, but it's not. Bring em both.
Old 12-09-2005, 12:31 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
100% Out of the 20 vehicles I have owned in the last 21 years, I'd have to say the 2 worst vehicles I have ever had to change the oil on are my 2 1997 Ventures. The filter is in an awkward position, and I can always expect a mess when I undo it to replace it. The drain plug isn't that bad though.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
