Old 12-09-2005, 06:00 AM
wnrandall wnrandall is offline
Send a message via AIM to wnrandall Send a message via Yahoo to wnrandall
Thumbs down 1988 S10 Door Handle Problem
I have a 1988 Chevy S-10 Pickup.
As I was leaving work this morning, my drivers side door was frozen shut. A friend of mine pulled on the handle and completely snapped it off.
I have found a couple websites that offer replacement parts, but I was wondering what all I need to do to fix this and about how much it costs to replace???
Old 12-10-2005, 05:01 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: 1988 S10 Door Handle Problem
Not sure on cost,but you should just need a handle.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 12-10-2005, 07:41 PM
NoSpudsInIdaho NoSpudsInIdaho is offline
Your cost shouldn't be too bad, I think I paid under $10 for the handle on my '89 at my local Carquest dealer last year. It's not too difficult to replace, but you need to be a little flexible and good in tight places. You have to remove the door panel and remove two retaining bolts from the inside through one of the access holes. Just try not to drop the bolts - they're not easy to fish out of the bottom of the door.
Old 12-11-2005, 09:09 AM
dugie6551's Avatar
dugie6551 dugie6551 is offline
Cost will depend on what you broke. Try a junk yard if you broke a rod inside the door or even the handle. It will be a dirt cheap fix, but more time consuming.
Make sure you have a telescopic magnet ... to pick up the bolts that might fall inside the door. "Been there, done that, got the tool ... now"
Originally Posted by lamehonda
AF has ruined my life. .... Thanks AF
Old 12-14-2005, 12:37 AM
Thanks! I ordered the part and all should be well.....I hope.
*crosses fingers*
Old 02-25-2006, 02:54 AM
S10er_1 S10er_1 is offline
Exclamation Re: 1988 S10 Door Handle Problem
My handle broke 3 times before I found a better solution. The cheap plastic breaks easily, especially in cold weather. I got a Billit Aluminum handle and it works great. Try 3rddoorhandle.com
Best of luck to you.
