Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-09-2005, 05:14 AM
brownevp brownevp is offline
fuel usage
i was needing to know if a 2004 crown vic police interceptor uses more fuel at idle or contenuiously turning on and off the vehicle
Old 12-09-2005, 04:26 PM
ModMech's Avatar
ModMech ModMech is offline
Re: fuel usage
WAY WAY more at idle.
Old 12-21-2005, 11:17 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: fuel usage
Shutting it on and off continuiously also causes way more engine wear in the long run, so running prolongly at idle is your best bet
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 12-22-2005, 12:08 PM
ModMech's Avatar
Re: Re: fuel usage
NOT.
Where did you come up with that theory?
New CVPIs have hour meters to monitor idle time. Ford considers every hour of idle time to be equal to about 30 miles of driving for oil change purposes.
So at 15 MPG, you are burning nearly 2 gallons/hour to go no where. The engine runs hotter at idle, and burns MORE fuel, neither are good for oil life or the engine in general.
Every idle hour on an engine reduces it time-to-overhaul about 25,000 miles based on testing done by both Cummins and Caterpillar.
