Go Back   Automotive Forums Car Chat > Honda > Locations (USA, Canada, Asia, etc...) > Europe
Europe England, Holland, Denmark, Germany, etc...
Old 06-04-2002, 06:17 PM
Civic 1.6i VT Civic 1.6i VT is offline
VTEC Controller
I have sourced a Spoon VTEC Controller for a JED EF8/EF9. It allows VTEC to cut in at 4800 rpm & redline 8900 rpm. I am told it plugs straight in using the supplied harness.
Does anyone know if I can simply plug it in to my EDM (EE9) Civic?
Will I need to change ECU etc???
Thanks.
Old 06-06-2002, 08:04 PM
Vitinho Vitinho is offline
Talking
Hi,
As far as I know, and I assist in instaling a couple (Apexi and Field), if you have the propper connectors it is very easy, Its like PPP (Plug, play and pray) . If you dont have the propper connectors you will need some tap connectors and it is still easy.
Apply the RFM (Read the fu#%ing manual) technique and read the instructions several times untill you feel confortable with the all process, this help a lot. Don't forget to check, double check and tripple check everything before you turn the key on.
Good luck.
Best music starts after 8.000 RPM !
Mods:
AEM CAI
Ractive Tripple Core spark cables
Custom mid-section exhaust pipe
Custom 280 x 28 disk brakes
Upgraded front brake callipers
Ferodo Racing pads (DS3000 for track, DS2500 for street)
Front and Rear Struct bar
Yokohama A539 195/55/15 (street use)
Avon Intermediate slick's (Track use)
Kony Sport CoilOver fully adjustable
Energy Suspension Hyperflex bushings
Webmaster of www.vtecpt.com (The portuguese site for Honda and VTEC fans)
Old 06-06-2002, 08:27 PM
Grendel's Avatar
Grendel Grendel is offline
Do those vtec controllers really work? A friend of mine was thinking of getting one for his GSR...
I would think that the guys at honda knew what they were doing when they set the RPM that vtec engages at... *shrugs*
-Grendel
Old 06-07-2002, 05:20 AM
Talking
Yes, they really work. We canīt forget the factory Honda Setup was design to take advantage of the power delivery while saving fuel.
Once you put a VTEC controller, you can take the fuel saving further more or you can improve the engine response starting at 4500 RPM. You take the choice instead of the ECU making the choice. If you are running a trip and you want to save fuel you can set up the VTEC to engage at 6500 RPM and you can save a lot of fuel. On the other end if you are "Racing" the car you can set it up at 4500 and if you shift from 2nd to 3rd you will be allways inside the VTEC power band. Some of the VTEC controllers can also setup the fuel injectors.
Regards,
Mods:
AEM CAI
Old 06-10-2002, 08:33 AM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
Regards,
But the problem is that you canīt just put it on and everything will be fine. You have to set it up with a dyno otherwise it wonīt work properly and may even damage or destroy your engine. And youīll need some other modifications like cams, CAI and stuff like that to see a real gain. One of the best controllers on the market is the Apexi VAFC but IMO itīs way too expensive.
Old 06-11-2002, 02:36 AM
Predator's Avatar
Predator Predator is offline
Send a message via ICQ to Predator
Veetec is absolutely right!
U cant just install the controller and put the kick- in point to 4000! The point must fit ur setup- and if ure running stock I really doubt that ull get any advantage!
play da game for fun not fame
what for idiots... theyre discussing about a law were u have to switch on the lights the whole day but when u switch on the fog lights without fog u have to pay for this 'criminal act'...
ZOMTEC rulez!!!
Apex AFC vtec controller??? Is it worth it PoisonFangs '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 26 04-08-2002 11:50 PM
vtec controller????????? onesojourner '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 03-08-2002 12:36 PM
vtec controller cnycivic Engineering/ Technical 2 03-04-2002 07:34 AM
VAFC Vtec Controller baldwonder Eastern US 4 02-11-2002 03:03 PM
Need Info on ECU chips and Vtec Controller Henweee Accord/TSX/Accord Hybrid 3 11-02-2001 03:26 PM
