Old 12-08-2005, 09:57 PM
CrxBaybee's Avatar
CrxBaybee CrxBaybee is offline
Send a message via MSN to CrxBaybee
Unhappy Weird Clutch Noise
Hiya, i was wondering if anyone could please tell me why mi crx is making a weird noise sumtimes on accelertation like the clutch may b slipping?, i dont kno how to tell what needs fixing, and also mi car surges wen idling, if anyone can give me sum advice it'd b much apreciated, thanx
Old 12-08-2005, 11:51 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Weird Clutch Noise
vaccum leaks number one reason for surge issue probably...look at the hoses and see which one is cracked...for clutch think drive it out of first drop it in second and smash on the gas and you will be able to tell if it slips....
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 12-09-2005, 01:43 AM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
to check for slipping you could also, driving like 15 mph put it in 4th gear and accelerate. if clutch slips you will feel it!!. For surging idle you also could try cleaning out IACV with some TB cleaner & Beeding coolant system of air as this would also cause idle to surge. If it surges pretty rapidly back and forth i would say vacumn leak as YZ125rider21 mentioned.
GL and Welcome to Forum
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 12-09-2005, 03:26 AM
hey man I ment to get back to you...You lock thing is broke cause i cut it like one the guys said on here to do but to come to find out you gave me wrong year...so you wont want it...but i have it still want it...it wont turn even with the key in it...lol...I not taking no advice from the guy said to do that again...but where do you live at?
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 12-09-2005, 04:01 AM
Jos4DCivic's Avatar
ahh its cool dude. same shit happen to my old one. broke that shit trying to get it in. just keep it or throw it away or what ever. let me know if you ever need anything else Bro!! oh and im on Cali coast
91 Hatch SI
Finally painted!!!
Old 12-09-2005, 06:37 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
ok, the first two posts are alright, but try to keep from thread jacking guys, use the PM button.
The "weird" noise coming from your tranny is most likely the throw out bearing, a slipping clutch doesn't make any noise, just doesn't engage as quick as it should. If its the throw out bearing, i would go ahead and get a clutch kit and replace everything while you have it out, the throw out bearing will come with the kit.
As for the surging, the other 2 guys are right, and that should fix that problem.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 12-11-2005, 08:48 PM
welfarepc welfarepc is offline
hey CrxBaybee does it sorta get louder sometimes, in first and second usually, and its when u start to accellerate?
but then again, sometimes it doesnt make the noise? (but usually does) cause if so, thats what mine does.
if its the throw out bearing, how hard is it to replace. just did the cv axles and installed coilovers without too much difficultly...
thanks
Dan
Old 12-11-2005, 09:04 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
its hard to tell you whats going wrong with your car is you cant describe the noise at all
Team Lonely Drivers
Old 12-12-2005, 06:55 AM
Hybrid1990crx's Avatar
yeah you are kinda vague on the noise.
if its a throwout bearing out will only hear it when the clutch is pressed in. it could also be a pilot bearing to.
Either one of the two means you have to remove the tranny. and for the pilot bearing you have to also remove the clutch and flywheel. not too hard of a job at all.
