Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 12-08-2005, 09:50 PM
jsgold jsgold is offline
1999 oil light
I have seen several posts on oil lights but ours is doing something a bit different. Has given us no problem so far, other than a little oil burning (2.7, 104K) but this evening my wife took it out for a short trip and when she came back she told me the oil light was stuck "on". It came on while driving, and would not turn off even when the car was shut off. I went out to look aand sure enough the oil light was on, the transmisison gear selector light was on, but nothing else. Car had oil, and when I started it up it ran as smooth as always. Light went off, and when I turned it off both light stayed off. Sounds a bit strange. I remember that her inside lights stayed on one evening for a while until I opened her door and re closed it (was closed, not open). I wonder if perhaps there is a malfunction with computer. Anyone had these symptoms??
I used to be indecisive, now I am not so sure.
Old 12-09-2005, 02:35 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 1999 oil light
if your trans selector lights and the oil light stay on even after the engine is shut off and w/ the key out of the ignition (if I understand you correctly) that sounds like a glitch in the BCM. Try disconnecting the battery for about 5 min. and reconnecting it, you'll be resetting the BCM; see if that works if not, then you have a definite glitch in the BCM.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 12-09-2005, 02:46 PM
Thanks, will give it a try.
Old 12-09-2005, 03:25 PM
1thunder 1thunder is offline
Re: 1999 oil light
do you have a remote start? if so your problem may be in there seen this before
Old 12-11-2005, 11:30 AM
No remote start.
