Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 12-08-2005, 05:56 PM
da_rookie_77 da_rookie_77 is offline
heating problem in an 2001 cougar
I have a 2001 mercury cougar with a 2.0 liter 4 cylindar engine and the heater does not work right. When the outside temperature is around 35 degree's or above the heater blows warm air. If the outside temerature is around 30 degree's or below it will only blow cold air. Iv changed the thermostat and it didnt help any. I was wondering if any one could tell me whats wrong with it? or how to fix this problem?
Old 12-08-2005, 07:10 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: heating problem in an 2001 cougar
could be the blend door actuator.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-09-2005, 03:48 AM
KimMG KimMG is offline
AF - Advisor
What temp thermostat are you using? Are both hoses going to the heater core hot when the car is up to running temp? Is the blend door sticking?
