Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 12-08-2005, 02:35 PM
02gmcsonoma 02gmcsonoma is offline
02 Sonoma service engine soon lite
Code PO128 kept coming up.Changed thermostat and will see what happens.Any other repair suggestions for this code??
Old 12-16-2005, 10:40 AM
gmc2003ZR2 gmc2003ZR2 is offline
po128 code, coolant temp was low...
P0128 - Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
I just added coolant to my zr2 and the temp is runing around 160+- when it usually runs @ 240+-.
Is it safe to drive if coolant resivior is full?
How do you clear this code?
Do I need a new Tstat?
Does it need to be cleared by a shop computer?
Is it hard to change, if you are mechaniacally inclined)
any help is much appreciated!
Matt
Old 12-17-2005, 02:09 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
If you added coolant, check for a leak
YES, but see answer above
You need a bi-directional scanner....you can try disconnecting the battery, but that doesn't always work
Possibly, but I would check for leaks first
Answered that one already
No
You are welcome
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 01-01-2006, 06:31 PM
serpentracer serpentracer is offline
first of all your temp is normal at 160
240 is not
you can also clear codes by pulling the ecu fuse.
my truck had this code before I cleared it and it has not came back on. I have a scanner and it clears codes. I have not tried the fuse deal.
if your temp is running at 240 you probably need a new thermostat. and make sure you have sufficiant coolant levels in the radiator and overflow tank.
