Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-08-2005, 02:11 PM
robkansas robkansas is offline
Angry 1995 Cutlass Supreme
I am having trouble opening my doors. I have had the inside mechanisms replaced on both sides. One person said the door was to heavy for the hinges and wanted $400. to replace! It seems to really get bad when the weather changes. I can open from the inside but not outside. HELP!!
Old 12-08-2005, 05:54 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1995 Cutlass Supreme
If the door handles are the pull up variety you problem is in the mechanism itself not the hinges. I had an 88 Cadillac and had the same problem. You will need to get new handles and when you replace them open up the doors from the inside and make sure the connecting hardware is not bent or damaged. Usually the handle bends or wears out and causes this problem. Tell Mr. $400 to pound sand this is a simple fix and shouldn't cost more than $100 if you make the repairs yourself.
Old 12-08-2005, 09:31 PM
galoosh galoosh is offline
I had the same exact problem with the passenger side door on my 1994 ragtop - the mechanism that prevents the door from opening too far was worn out so the door hit the hinge and bent just enough so the door would not open from the outside - adjusted the door and it works fine now. The door is too heavy for these hinges which causes problems like this. I thought it was the outside handle at first but it was unrelated to the problem
Old 12-09-2005, 01:06 PM
Could you tell me how you adjusted your doors? I took it to a body shop and they took a jack and jacked up the door, it lasted about 6 months and it is back to not opening. I would appreciate any insight that you could give me. Hopefully my brother-in-law will be able to help me adjust them.
Old 12-11-2005, 04:38 PM
Re: Re: 1995 Cutlass Supreme
if your problem is caused by the door opening too far like mine was, I gingerly used a piece of wood to bend the door back so it was no longer hitting the hinge (put the wood between the door and hinge and close the door slowly). My door buckled a little bit from hitting the hinge so once i bend out the buckle it worked fine. Just make sure not to open the door too far again!
Old 12-13-2005, 09:08 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
I fixed a broken lock on a car with a simliar door. handle. that is the pull up handle. when you pull it up it pushes a rod down. you may just need to adjust the rod so its a little longer. so when u pull the handle it pushes the rod all the way down.... if the hinges are the problem you may have a problem somewhere. take a close look. look for bends or something that doesnt look normal to you...
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
