Old 12-08-2005, 02:20 PM
BryanCa BryanCa is offline
03 Caravan SE Fan Switch Problem
The fan switch on the dash will only operate on HI. The van has dual climate control. The other switch operates fine. Do I have a bunk switch? I want to avoid the dealership at all costs. I can probably fix this myself, except I don't know how to diagnose this issue. Anyone have this problem? I've put up with this all summer long, but I just had a baby and I need to regulate the temp better. I found an old thread from early 2005 that someone stated the fan switch resistor was the culprate and not the switch. Maybe it is the switch. Would this possibly be the same problem? Dont' know where this(resistor) would be located on the van either. Can this part be purchased at Autozone/O'Reilly??
Old 12-08-2005, 09:32 PM
vipergg vipergg is offline
Re: 03 Caravan SE Fan Switch Problem
Replace the blower motor resistor . It is located directly behind the glovebox on this era van , on 96-2000 models it's under the hood on the passenger side under the wiper cowl.
Old 12-08-2005, 10:08 PM
Re: Re: 03 Caravan SE Fan Switch Problem
Does this part just plug into a wiring harness? Is this part available at the local auto parts store? Any idea how much? Thanks for the advice.
Old 12-09-2005, 12:27 AM
Re: Re: Re: 03 Caravan SE Fan Switch Problem
I found it. Like everyone said...literally behind the glove box. Very easy to get to. Now I have to get the replacement part.
Old 12-12-2005, 07:54 AM
HeadlessHorseman's Avatar
HeadlessHorseman HeadlessHorseman is offline
Send a message via AIM to HeadlessHorseman
Yep, it surely does sound like a bad Resistor Block. Everything you need to know about the Resistor Block, symtoms, problems and more is right here (including part numbers and where to get them)...
http://www.automotiveforums.com/vbulletin/t340871.html
Good Luck!
