Old 12-08-2005, 11:07 AM
hoopin hoopin is offline
Cool Power Steering Return Hose Length
Windstar Power Steering Pump
What is the approximate length of the power steering return hose?
Old 12-08-2005, 11:18 PM
wiswind wiswind is offline
Re: Power Steering Return Hose Length
Best thing I would know, would be to use a piece of string to lay onto the hose.....and then measure the string....Buy just a little longer than you measured....
The length may or may not be different from year to year.
Old 12-09-2005, 08:27 AM
Re: Re: Power Steering Return Hose Length
Thanks for the heads up
I'll be doing the job this weekend.
Is the power steering fluid supposed to be black?
Old 12-09-2005, 09:21 AM
garync1 garync1 is offline
Re: Re: Re: Power Steering Return Hose Length
Nope.. but make sure you use the right type of fluid some years use tranny fluid .. My 2001 does. I just used dextron/ mercon works great...
Old 12-09-2005, 12:50 PM
Re: Re: Re: Re: Power Steering Return Hose Length
I have a 1998 Windstar with 100,000 on it still runs pretty good.
Thanks for all your help guys/gals.
I think I can used tranny fluid in the steering
Old 12-09-2005, 06:27 PM
I would use Mobil 1 ATF, which is a Mercon Synthetic....if your '98 calls for Mercon. The synthetic will take the heat better...and give you better cold flow.
Do a search in this windstar room on power steering fluid....and you will see several posts on how to flush it. I ran 3 quarts through to flush it out.
