Old 12-08-2005, 10:31 AM
ton394's Avatar
ton394 ton394 is offline
need help on painting headlights and tailights
hi there! i am new on this type of hobby.. can anyone help me or give an idea about painting the headlights and tailights.. my kit is a fujimi honda civic sir II ek4.. if you have some pictures that would be great.. tnx
Old 12-08-2005, 10:49 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Re: need help on painting headlights and tailights
What exactly is the problem?
Old 12-08-2005, 11:02 AM
winstona's Avatar
winstona winstona is offline
This may help:
http://www.automotiveforums.com/vbul...ing+headlights
I found it by searching the forum.
Winston
Old 12-08-2005, 11:04 AM
freakray freakray is offline
AF Modelrater
Re: Re: need help on painting headlights and tailights
Originally Posted by winstona
This may help:
Winston
Thank you
You're the model n00b
AF User Guidelines
Old 12-08-2005, 11:23 AM
winstona's Avatar
Re: Re: Re: need help on painting headlights and tailights
Originally Posted by freakray
Thank you
Just trying to help
Old 12-08-2005, 11:53 PM
ton394's Avatar
thanks to winstona, by the way what are the time intervals between coats on the clear part? and how many coats will i apply? can i use flat colors such flat red and orange for my rear tailights..?
Old 12-09-2005, 02:13 AM
cham2020's Avatar
cham2020 cham2020 is offline
Send a message via ICQ to cham2020 Send a message via MSN to cham2020 Send a message via Yahoo to cham2020
i use permenant markers for my clear parts
results are acceptable
Old 12-09-2005, 02:18 AM
cham2020's Avatar
here are pics for ur reference
p/s _ the model is not yet complete
the windows are black cause i accidentrly screw the clear parts..hehe....
Old 12-09-2005, 09:24 AM
winstona's Avatar
I am no expert here but I will try my best to answer your questions...
Leave about 30 minutes between coats if you apply a thin coat. Most of the time you only have to paint the inside. Sometime when you encounter a very thick clear piece, you may have to paint both sides.
Don't use flat red/orange, use CLEAR red/orange. Remember you have to see through the clear parts not cover them. You need Tamiya X-24 clear yellow and X-26 clear orange (I only know tamiya colours and their codes). I am sure you can find these same colours from other companies too.
Winston
Old 12-09-2005, 09:44 AM
chenc544's Avatar
chenc544 chenc544 is offline
Don't forget to paint the edges flat or sem-gloss black. It makes all the difference.
BTW, I can never get the red or orange to come out the way I like it so I usually just decide that I like the clear lens look better...
Old 12-09-2005, 09:59 AM
cham2020's Avatar
eh guys
how is the lamps painted by markers?
Old 12-09-2005, 10:41 AM
ZoomZoomMX-5's Avatar
Originally Posted by cham2020
eh guys
It's very simple. I usually use a red Sharpie to tint taillights these days. I carefully use the marker to color in the backside of the clear lense. I use a pointed tip. I don't have a how-to, I guess I should do one to illustrate. But it's dead simple. Just take some of the clear plastic sprue that the parts come on, and try out a red Sharpie on it to see how it works. Sometimes you need to go over it a couple times. I find it MUCH easier than dealing with Tamiya clear red. It dries thin and fast. You can retouch it if necessary. Much more forgiving than using paint.
I use three colors of Sharpies on a regular basis. Red for taillights, silver for some detailing, and black to make the black inner window masking and to outline the edges of many modern headlight/taillight lenses. It's so fast and easy and it really makes the models appear more realistic.
Here are examples where a red Sharpie marker was used:
This one on the Frogeye Sprite I used the Sharpie on the outside of the lenses. Usually I apply it inside, but it's okay if you need to apply it outside. It dries thin and flat.
Maranello I believe I tinted both inside and outside the lense.
The orange side lense was Tamiya clear orange. Sharpie orange is a bit dark for amber.
Over black reflectors.
Over silver painted reflectors. Notice how this brightens the red lamps considerably. I intended the gray car above to have darker lenses as part of the "blackout" theme of the rear panel.
My Fotki Album
Old 12-09-2005, 11:15 AM
cham2020's Avatar
Zoom
the method u are using is same wit me
i am using artline permenant markers
in the evo VI pic i posted, i colored then both outer and inner side.
anyway i love your models, damn cool.....
Old 12-10-2005, 05:23 AM
klutz_100's Avatar
I have nothing more to add, I just wanted to congratulate ZoomZoom on his awsome builds!!
