Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 12-08-2005, 10:03 AM
cjcivic cjcivic is offline
lost abs
after i put a b18c1 into my 94 civic ex w/ abs i lost the abs. i never read anything about this happening. does anybody know why that happened and if it can be fixed?
Old 12-08-2005, 12:35 PM
97integrals's Avatar
97integrals 97integrals is offline
Re: lost abs
Well first I would suggest you try to find the abs, with it being lost and all.
Old 12-08-2005, 10:42 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
Re: Re: lost abs
ahahaha too funny
Old 12-09-2005, 12:12 PM
Re: lost abs
that was hilarious. did u think of that all on ur own?
Old 12-09-2005, 03:50 PM
Re: Re: lost abs
They reason I made a joke instead of giving you any advice is because, like most of the recent posts on A-F, your post is devoid of any information what-so-ever that could help anyone give you a good answer.
For example: I just installed an h22 in my civic and I lost fuel injection can you help me.
How can you post something so vague and expect to get decent responses?
Old 12-11-2005, 10:10 PM
Re: lost abs
i have no clue of anything else that happened. i have no clue why the abs does not work n e more. all i know is that it worked before i put the engine swap in and did not work after. i just wanted to see if anyone else might have had this problem and if they did maybe someone could help me out and steer me in the right direction.
Old 12-11-2005, 11:35 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: lost abs
did you have to swap axles in your swap?? If you did, you might not have gotten the speed sensor dealies on the axles....or are those on the hubs??
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-12-2005, 10:50 PM
Re: lost abs
i got used axles with the swap from a 94 gsr and i am almost positive that the speed sensor is on the top of the tranny
Old 12-13-2005, 09:32 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Ok, do your new axles have the ring on the wheel side? It has little square teeth cut out of it. Second, did the car the axles came out of use a different wheel speed sensor? If so, you might need those. Otherwise, your new computer doesn't support ABS. If it is throwing a code, then tell us that, it might help to figure it out.
