Old 12-08-2005, 10:30 AM
cleanshavenrsx cleanshavenrsx is offline
Send a message via AIM to cleanshavenrsx Send a message via MSN to cleanshavenrsx
spark plugs and cap on 95 s10 blazer
how in the hell do you get at the spark plugs and cap????
Old 12-08-2005, 12:00 PM
Cailen Cailen is offline
Re: spark plugs and cap on 95 s10 blazer
There's a few threads on it already, but the best way to get at the spark plugs is through the front wheel wells (trust me, taking your tire off WILL save you a LOT of time).
As for the cap, reach!!! It's pretty easy to take off back there. You'll need a torx 15 I think (and I'm probably wrong about that :P)
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
Old 12-08-2005, 12:32 PM
Teal95Jimmy's Avatar
Teal95Jimmy Teal95Jimmy is offline
Send a message via AIM to Teal95Jimmy
#3 plug will be a b%*^C, jack the engine up a little so you can clear the steering shaft to get the plug out
Old 12-08-2005, 05:48 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Cailen is right, torx t15 screwdriver for the cap... For the #3 plug, remove the 11mm bolt at the bottom of the intermediate shaft and push it towards the firewall. It will collapse into itself (make sure the steering wheel is unlocked) and move it out of the way. 3 and 5 will be easy to get to when you do that. Don't worry about when you go to reconnect it, it's keyed so there is only 1 way it can go back on...
Old 12-08-2005, 11:46 PM
gorgon2k's Avatar
gorgon2k gorgon2k is offline
Send a message via AIM to gorgon2k
i strongly suggest getting the sparkplug socket with the flex head, it makes #3 easy as cake, and is usefull on all of them+ you dont have to jack the engine up
http://www.sears.com/sr/javasr/produ...&bidsite=CRAFT
Old 12-09-2005, 11:08 AM
You have one of those gorgon? Doesn't look like you'd be able to get it out with the plug after unscrewing the plug. Nice find though.
I just use my flex head ratchet.
