Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-08-2005, 08:07 AM
wesley's mom wesley's mom is offline
Surging and temp problems
I have a 1998 SL2 I am having a problem with the temp sensor (s) I am having the problem of surging while idle and while driving. I can literally watch the RPMs rise and temp gauge go crazy up and down. The temp gauge never gets over half way. I have replaced the sensor on the side of block twice (told first one was defective) that fixed it for a while then same thing starts again. Is there anything else that I should check or replace to fix this problem?
Old 12-08-2005, 10:52 AM
HAWG HAWG is offline
Re: Surging and temp problems
check the wire that plugs into the sensor for corrosion. we usually replace the sensor and connector for that problem
Old 12-08-2005, 04:00 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
yes check the plug, typical for corrosion. but too where did you buy the sensor and does it have a brass tip?
