is this also common
three times today when i've started my car it made a sound wet fan belt from under the hood of driver side. and i thought i might have head my power stering pump wind a little but not so sure gonna check it in the daylight tomorrow. any ideas
W O W!! !! so you have a honda civic
Re: is this also common
It's squeaking just when the turn the engine over? If so it's probably just a loose belt on the starter (or the belt needs replacing).
Time for you to crack open the hood and listen for squeaks. |
Probably is the power steering belt tensioner is a little slack (due to belt wear etc) just tighten it up and that should sort it
GTO TT - More power than GOD K&N Filter Stainless hiflow Downpipe Stainless hiflow Turbo elbows Stainless hiflow Manifolds Jamez 3" catback dual exit Boost @ 1bar Stock turbo's
it sounds like its comming from behind the motor next to the fire wall
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
