Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-07-2005, 10:38 PM
SteveArt SteveArt is offline
Question 1999 Dakota Heater will not get hot
My 1999 Dakota heater will not get hot. It takes a while to warm up but never gets hot. Can I put in a higher temp thermostat? Could it be another issue? Any input would be appreciated.
Old 12-07-2005, 10:44 PM
DodgeMagnum DodgeMagnum is offline
Re: 1999 Dakota Heater will not get hot
Have the system flushed,then have the heater valve checked. You might just bypass the heater control valve w/a pipe, run it direct. What temp does the temp gauge indicate, lower than normal?
Old 12-07-2005, 10:52 PM
Re: Re: 1999 Dakota Heater will not get hot
Guage reads between 130 and 210, I assume it's around 165/175. Air coming out of vents is almost warm but never hot.
Old 12-08-2005, 12:08 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
you might also want to check for air being trapped in the system.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 12-08-2005, 05:44 AM
IIRC, it should be around 195 or so. Does it seem to take a long time to warm up? A quick check would be to put cardboard in front of the radiator. I know, very old and tacky, but it'll tell ya if it's the thermo. or not.
Old 12-08-2005, 06:25 PM
Dakota00's Avatar
Dakota00 Dakota00 is offline
Send a message via MSN to Dakota00
you probably need your heater core flushed out. I know a few guys who did this and it worked like a charm!!
Old 12-09-2005, 01:15 AM
I'll try that. I called the car part store to see if that year of Dakota had different temperature thermostats. There are three, 165, 175 and 195. My temp seems to stay around 165 so it may have been changed out at some time. I don't know the history of this truck, I just purchased it. They told me the 195 was stock and That's what should be in it, anything else could mess with the computer. I will check it out this weekend. Thanks for the advice
