Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-07-2005, 09:46 PM
LostWages's Avatar
LostWages LostWages is offline
Headers or Intake ??
Ok so I don't know much about cars... I have a 1995 Civic DX 2Dr and I was intrested in getting a little more performance & Hp for my little car... I know a short arm intake is a quick cheap fix, a Cold Air Intake is a little better... Headers I know nothing about really.. What's the advantage of a 4-2-1 one piece compared to a 4-2-1 two piece ?? Or a 4 into 1 ??? WTF is the difference ?? I'm fairly sure that if I want the desired results i'm looking for I should probably get both right ?? Any help/advise would be appreciated... Please speak normal english if you can, my car knowledge is very limited... I'm suprised I even know what I just typed...
Thanks...
Old 12-07-2005, 10:04 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
Re: Headers or Intake ??
depending on the header design youll get power at different points in the powerband...if you just want a LITTLE more power get intake header and exhaust...if your a little more serious about making your car faster there are more options...
Old 12-07-2005, 11:27 PM
LostWages's Avatar
Re: Re: Headers or Intake ??
Meaning the acceleration in different gears ?? I'm looking to just get more response when I press the pedal, in first or 5th... What do you suggest... Thanks for the quick response...
Also should i not even worry about any Mods if my engine has 140k on it ?? Should I just wait for the eventual swap ??
I never MISSED MY HORN SO MUCH IN MY LIFE !!
Never realize how many stupid ass drivers are in Vegas till your horn fails !!
Old 12-08-2005, 08:33 AM
how much $$$ do you have? or how much are you willing to spend? about the header 4-1 will give you more power in low rpm and 4-2-1 header will give you more power in the higher rpm...so you can make that decision...most people with hondas go with the 4-2-1 design because hondas lack of torque
Old 12-08-2005, 09:53 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
and generally a 4-2-1 is cheaper and definately easier to install...i would get the one piece so that you have one less gasket in your exhaust that could leak...
but honestly there isn't a lot you can do to make that stock non-vtec engine a lot faster.....sorry
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-08-2005, 11:10 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
That's not true.
Since you're a newbie though. Get an intake first. Then if you like get a 4-2-1 header. Note: 4-2-1 is for low end and 4-1 is high end. If you want to keep that engine and/or rebuild it you don't need vtec. There are other options, but it depends on what you want.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 12-08-2005, 11:50 AM
Schister66's Avatar
AF -Advisor
all that stuff istn't going to make that engine a lot faster tho....its going to help without a doubt, but its not going to make a huge difference....
The only way to make a D fast is to put it in a light car or boost it....
Old 12-08-2005, 06:41 PM
Schister66 is right...the only way to make a D fast is to boost or unless someone can prove me wrong
Old 12-08-2005, 06:42 PM
and in my 2nd post i meant the 4-1 for high end and 4-2-1 for low end
Old 12-09-2005, 03:48 AM
Schister66's Avatar
AF -Advisor
damn right i am....
Old 12-10-2005, 02:40 AM
LostWages's Avatar
Ok so I want to go with a 4-1 one piece for high end cool... Also what do you mean by "D"... DX ?? Thanks for your help guys :-)
Old 12-10-2005, 04:58 PM
what we mean by D is a D series engine...which is what you have now and is what most civics have without a swap
Old 12-10-2005, 09:05 PM
LostWages's Avatar
Seeing that I have 140k miles should I just wait to do anything before I swap ?
Old 12-10-2005, 09:08 PM
Schister66's Avatar
AF -Advisor
are you going to swap for sure...you could save your money, rebuld the d, maybe a mini me (nonvtec to vtec head swap), then boost the shit out of that engine!! You could make 300whp daily on a built turbo D.....or you could make less or more depending on your budget and goals....
Old 12-10-2005, 11:04 PM
Kven's Avatar
Kven Kven is offline
bisi; nonvtec d15 and f22. yes its alot of money, but its still nonvtec. the only disadvantage to nonvtec is bad idle with high duration cams; if you can live with a high idle though it wouldnt be a problem. Hell, theres a guy with a D15B2 racing in a SCCA event thats pushing about 160-170whp; more than some b16s.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
