Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-07-2005, 07:56 PM
wtjpcardinal wtjpcardinal is offline
93 Camry rear defogger not working
I have a 93 Camry that the rear defogger does not work on. The light comes on when the button is pushed and it stays on for about the normal 13 minutes, but it doesn't heat up. Could this be a relay? If so, where would it be located and how I gain access to it? Thanks for any help.
Old 12-07-2005, 09:44 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 93 Camry rear defogger not working
The defogger relay and the DEFOG fuse (M-fuse) are in Junction Block No. 1, by the driver's left knee.
It could also be the wire in the window, the choke coil, or the wire harness.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-07-2005, 09:53 PM
Brian R.'s Avatar
Resident Chemist
Old 12-07-2005, 09:54 PM
Brian R.'s Avatar
Resident Chemist
Brian R.'s Avatar
Resident Chemist
Old 12-08-2005, 05:14 PM
Thanks for the replies. Hopefully one of these is the culprit.
Old 12-08-2005, 05:37 PM
Brian R.'s Avatar
Resident Chemist
You're welcome. Good luck.
Old 12-10-2005, 06:04 PM
Re: Re: 93 Camry rear defogger not working
Are the relay and the fuse the same thing? I took out one that is small and a square top and the defogger light on the switch wouldn't come on. Is it same to say this isn't the problem? My rear window is tinted. Does that rule out checking the wires? Thank you
Old 12-10-2005, 08:52 PM
AccordCodger AccordCodger is offline
No
A tinted window oftem means that the heating element HAS been damaged. Window tint people aren't very careful. And that's especially true if the tint has ever been replaced.
Old 12-10-2005, 11:02 PM
Originally Posted by AccordCodger
No
Under normal circumstances, I would think the same, but it wasn't working before the tint. Thanks
