Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 12-07-2005, 04:52 PM
whack_lac whack_lac is offline
Shifting issues
I have a 1999 STS with 80k. Recently when I shift into drive it feels like it is dropping into gear way too hard. There is a "thud" noise and the front end of the car will bounce slightly. Shifting into any other gear is smooth as butter. It happens probably 90% of the time. The rest of the time it goes into gear smoothly. Also when I pull away from a stop (already in gear) there is a slight delay with a very similar "thud". Occasionally at cruising speed when I coast from say 55 to 45 and get back on the gas I have the same delay and "thud". Once I'm going I can put the hammer down with no problems whatsoever.
Please help!!!!
Old 12-07-2005, 06:02 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Shifting issues
May be time to check engine and trans mounts.
Or anytings else that may be lose.
MT
MT
Old 12-09-2005, 09:00 AM
caddydaddy caddydaddy is offline
Re: Shifting issues
Yeah, the motor mounts are a fairly common failure on the high mileage Sevilles. I'd check those first as mentioned.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
