Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 12-07-2005, 04:50 PM
krayflesh krayflesh is offline
Just a quick question intrepid not starting.............Please help!!!!!!!!!!!!!!!
I have a 99 intrepid, it starts OK when the car is cool. In the
mornings...one turn of the switch and the car starts..it takes me to work,
the car sits all day..one turn of the switch and it starts, drives home
perfect. THE REALLY BIG PROBLEM IS THAT I CANT TAKE MY WIFE SHOPPING....The
car will not start if I turn the motor off for a short while. The motor
turns beautifully but will not start. If I wait any where over 40mins the
car starts right back up with just one turn of the switch. I have
diagnosed the PROBLEM AS: THERE IS SOMETHING UNDER THE HOOD THAT NEEDS TO BE
REALLY COOLED DOWN FOR THE CAR TO RESTART. I HAVE GOTTEN SO GOOD AT THIS,
THAT NOW WHEN I STOP FOR A SHORT TIME......I OPEN THE HOOD AND WHATEVER
NEEDS TO COOL OFF....COOLS OFF A LITTLE BIT FASTER BECAUSE THE HOOD IS OPEN.
ONCE THE CAR STARTS IT DRIVES PERFECTLY...DOS'NT SHUT OFF ON ME. NOW..I
REALIZE I CUT MY WAIT TIME TO ABOUT 20MINS BECAUSE THE HOOD IS OPEN. I AM
FIGURING THAT THIS HAS SOMETHING TO DO WITH SOME SORT OF COIL OR SENSOR. I
HAVE ALREADY CHANGED THE CRANK SENSOR, CAM SENSOR, SPEED SENSOR (BOTH), MY
COOLING SYSTEM IS PERFECT, NOW I AM ABOUT TO CHANGE THE OXYGEN SENSOR, C02
SENSOR, AND OIL SWITCHES. I HAVE NO IDEA WHERE TO FIND THE COIL. my starting
problem is nothing like i have been reading for other people MY CHECK ENGINE
LIGHT DOES NOT COME ON, NO CLICKING SOUND ENGINE TURNS PERFECT.. JUST WONT
START WHEN HOT. PLEASE HELP MEEEEEE.
Old 12-07-2005, 10:17 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Just a quick question intrepid not starting.............Please help!!!!!!!!!!!!!!!
it sounds like you're getting vapor lock in your fuel system, that is, when it gets warm, the fuel has a tendency to vaporize b/c of the heat. Once the heat goes down, it can maintain the pressure it needs to start-up. I'd suggest having your fuel pump checked out and have a pressure test done on the fuel system, known as a leakdown test. Normal fuel pressure should be around 45-50 psi +/-5 psi. If it drops more than 5 psi in one hour, you've got a problem either in the fuel pressure regulator, or pump itself. The ironic thing is that if your pressure regualtor goes bad, you'll have to replace the fuel pump anyway since it's attached to your fuel pump module inside your fuel tank.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
