Old 12-07-2005, 03:55 PM
bad3kgt's Avatar
bad3kgt bad3kgt is offline
Send a message via AIM to bad3kgt
Burning up the headlight wires?
i was thinking about getting the H-4 Headlight Wiring Harness from 3Sx performance, and i was thinking about getting the iceburgh blue bulb of this. http://cgi.ebay.com/ebaymotors/XEON-...18421327QQrdZ1
But i remember somebody saying in here that they burned up there headlight wires cause it ran too hot. Do you think it will be ok ?
==--92 Mitsubishi 3000gt SL--==
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Unorthodox Underdrive Crank Pulley
Bomex Bodykit
18x8 Chrome rims
Old 12-07-2005, 04:13 PM
Beef66 Beef66 is offline
how do these compare to HID kits?
Old 12-07-2005, 04:23 PM
bad3kgt's Avatar
Re: Burning up the headlight wires?
I dunno, im just lookin to get that blue-ish look with my headlights.
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Bomex Bodykit
18x8 Chrome rims
Old 12-07-2005, 05:35 PM
2old 2old is offline
HID kits don't fit in pop up headlights (at least the ones I have been looking at) and if they do they don't have High Beams (I am not willing to sacrefice highway driving).
I have been running H4 lights for a few years and unless you run more then 100W you don't have a problem with the harness overheating... HID actually consume a lot less then Halogens if you can get them to fit in the pop-ups.
I was looking at that link and that looks like they are selling the bulbs but not the ballast (which is where the bulk of the cost is in).
If you just like the blue why not get Sylvania or GE nighthawk lamps?
Old 12-07-2005, 06:05 PM
bad3kgt's Avatar
I want the harness and the H-4 Diamond Style headlight set from 3SX, if i get those then i should be able to run those bulbs from that link right ? It says they come in H4's
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Bomex Bodykit
18x8 Chrome rims
Old 12-07-2005, 06:30 PM
The problem is not whether the bulbs will fit in the housing. The problem is that HID in H4 either do not have a high beam or the housing behind the H4 bulb extends too far back and it cannot fit in the frame of the pop up headlight.
If you are willing to sacrefice you high beams for HID the bulbs will fit but you it looks like the link is just the bulbs and does not include the ballast (the ballast is required for HID because it initially takes about 10,000 volts to start turn the Xenon gas into a "plasma". After the first spark, it's something like 35 volts to maintain the plasma).
I am just telling you this because the bulk of the cost of a HID conversion is the cost of the ballast and not the bulbs.
If you read further down on the link it says for installation, you need to plug the bulb into the ballast if you don't believe me.
Old 12-07-2005, 06:43 PM
Strike that... Ballasts have gotten cheaper over the last couple years... Just budget an extra couple hundred bucks...
You will still need to add that to you HID coversion shopping list.
Old 12-07-2005, 07:07 PM
im not 100% sure on this but im going to check later but I believe I have seen HID kits with both low and hi beams...
Old 12-07-2005, 07:27 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
YOu can get HID's in low and high for second gens for sure. I dont think you can get high beams for first gens though.
Old 12-07-2005, 07:49 PM
bad3kgt's Avatar
Yeah, let me know what you find cause i want those lights bad! =P
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Bomex Bodykit
18x8 Chrome rims
Old 12-07-2005, 08:45 PM
I've seen 2...
One had HID for High and low but is definitly too large for pop up headlights...
I have seen a second one HID low and Halogen high but I can't seem to find them again and I think they were also too large for the pop up headlights.
Old 12-10-2005, 12:23 AM
exterra3000gtsl exterra3000gtsl is offline
autozone has a headlight conector with a thicker wire that you can use, if you hotter bulbs in it...
