My washer fluid stopped pumping yesterday (bad time of year for that). I was looking in my owners manual to see what fuse it is on, and it doesn't say.
Does anyone know which fuse it should be? Where can I find information about the washer system? |
The pump runs off a circuit breaker which also protects the wipers. Does the pump run when you try to operate it? If it does, the lines may be broken or frozen. If it does not, is there current comming to it from the switch? Test at the connection with a multi-meter or test light.
The Haynes manual has a diagram that shows the wiper/washer circuit for both the front and rear. Your local Library may have it or you can get one at the parts store. |
