Heeeeeelp !!! AutoXray readiness test results ?!?
hi again,
I tested the truck ('96 Explorer 4x4, 4.0 V6) with the autoxray tool, and no error codes. but at the "Test result" section i had the following tests FAILED : - Upstream Static Shift - lean shift on HO2S11 - Upstream Static Shift - rich shift on HO2S11 - Rear to front Catalyst monitor switch ratio Bank 2 - Initial Tank Vacuum reading - Leak Check Vacuum Bleedup - Vapor Generation Maximum Pressure Rise - Vapor Generation Adjustment - Delta Pressure for Downstream DPFEE Hose Test anyone knows what this stuff means? Can theese cause poor engine runing and erratic gear shift (automatic trans. )? HEEEEEEEEEELP
