Go Back   Automotive Forums Car Chat > MG > MGB
Old 12-07-2005, 09:30 AM
gvorees gvorees is offline
mg circuit problem
when I start my 79 mgb, the tach and other functions (wipers, signals, brake lights, fuel gauge) work. As soon as I would activate one of the ancillaries, the entire circuit would drop out until I stop the engine, wait a few minutes and start it up then the same thing would happen. If I disconnect the voltage balancer right below the fuse box, the tach will fire up until I activate one of the other functions, the drop out again. Please someone HELP, I'm going nuts.
Old 12-11-2005, 07:20 AM
Flash75 Flash75 is offline
AF - Advisor
Re: mg circuit problem
Disconnect the battery and check the fuse box clips for the fuse connecting the white/brown wires to the green wires. Clean the contacts and be sure the clips have enough tension to maintain a tight fuse connection. Clean the metal ends of the fuse. This fuse feeds all the components you mentioned. I don't understand your comment about a voltage balancer under the fuse box. I'm not aware of a voltage balancer in the MGB. Can you describe it?
Clifton
Old 12-12-2005, 01:11 AM
KimMG KimMG is offline
AF - Advisor
Can you post a picture of the voltage balancer?
