Old 12-07-2005, 06:45 AM
FlyingGilles's Avatar
FlyingGilles FlyingGilles is offline
Drill bit sizes
I'm sorry, I've looked around but couldn't find anything about drill bit sizes. I want to buy some bits, since the ones I have are not small enough for 1/24 or smaller scales. could I get a rundown on sizes? I've looked for Dremel but didn't see anything small enough to do a 1/64in hole or smaller.
Richard, you'll be always remembered.....
Old 12-07-2005, 07:10 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Drill bit sizes
Squadron, X-acto and other companies make drill bits 61-80.
-Mike
Old 12-07-2005, 07:15 AM
Lambo003's Avatar
Lambo003 Lambo003 is offline
Not sure if there's one near you but Wood Workers Warehouse has sets of indexed micro bits. Can't remember how many come with it as my stepson raided my tools and lost half of them. . . Most any size you need comes in it and I think I paid under $20 for the set . . .
EDIT: Ummmm never mind . . . "Woodworkers Warehouse ceased operations and filed chapter 11 bankruptcy on December 2, 2003.
All assets have been liquidated." damn. . .
EDIT #2: Good news, look here. . . 11 bucks!!!
Chuck
Old 12-07-2005, 07:22 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
...they run from .039", which is about 1" in 1/24, to .0135", which is about 1/4" in 1/24. Good luck finding anything smaller than #80- that's appearently what lasers are for.
Should cover everything you should need in 1/24- just get some dial calipers so you can measure whatever you're drilling the hole for, too.
PHOTOBUCKET SUCKS
Old 12-07-2005, 07:25 AM
klutz_100's Avatar
Re: Drill bit sizes
Search for micro drills on ebay - I think you will find what you are looking for. here is a randomly picked example of what I have in mind.
Also, I don't think they will work very well in a Dremmel - especially the very small ones for wiring. You will need a pin vise/vice if you don't already have one.
HTH
EDIT: Ooops! 2 other posts before I finished writing mine!
Old 12-07-2005, 07:34 AM
Re: Drill bit sizes
very nice...thank you all!
Old 12-07-2005, 10:21 AM
jdmaccordian's Avatar
jdmaccordian jdmaccordian is offline
Send a message via AIM to jdmaccordian
I've been using this set for a few weeks: Pin vise w/ 30 bits . They work very well...all the way from 1/3 of 1mm to 2mm. Good luck.
djMS
Old 12-07-2005, 11:08 AM
klutz_100's Avatar
Re: Drill bit sizes
one other thing, stock up on more than one of the very thin drill bits (e.g. 0,3mm-0,6mm). They snap VERY easily and that's not a good thing to have happen when you only have one
Old 12-07-2005, 12:23 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
This is what I use.
Steve a.k.a. Hiroboy
