Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 12-06-2005, 08:19 PM
dbollinger dbollinger is offline
96 trans stuck in second gear
when comeing to stop it die on me when it started up it wouldnt shift
two days later went back to normal its done it again wont shift and when i put it in drive it dies.
took it to shop they checked for codes on the trans none came up.
any ideas on what is wrong and how i might fix it
Old 12-06-2005, 11:03 PM
bc42875 bc42875 is offline
Your tranmission speed sensor is bad. Replace it and it will be good as gold again.
BC42875
Old 12-06-2005, 11:42 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 96 trans stuck in second gear
you could also have a bad solenoid pack, very common thing to fail on these transmissions. bc42875 is also correct, but usually if the output speed sensor fails, your speedometer won't work, you haven't mentioned that, so I don't believe it's a problem. If the input speed sensor fails, it'll just stay in second gear, though your speedo will work. I'd recommend going to a shop that can manually test the solenoid pack w/ a scanner to see if that's indeed the problem, preferrably a Dodge dealer since they have the Chrysler DRB III scanner that can test each solenoid with the acutuator test. If you say it stalls, then more than likely it is the solenoid pack, but always check to be sure before you speed hundered of dollars fixing the problem.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
