Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 12-06-2005, 06:29 PM
ModifiedMCS ModifiedMCS is offline
2000 Elantra
I searched this forum and i couldnt find any answer related to my problem. So here goes: I have a 2000 Elantra with approx 63,000 mi.
The car cranks but no start. The only time it will start if i spray starting fluid. Then it will start up fine, and the motor idles perfectly smooth. I have NGK platinum sparkplugs(still good). I checked the resistence of the spark plug wires the longest wire (2.975Kohm) and the shortest is about 7 inches long (1.450kOhm). This is a distributorless ignition system. Fuel injectors are working fine. And there are sparks at the plugs. There are no check engine light.
TIA.
Old 12-07-2005, 11:58 AM
gbic1 gbic1 is offline
Having the same problem. It is 4 degrees here and when cranking over I have no injector pulse. Plugs are good and I have spark. I also have no power to the injectors.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 12-07-2005, 02:44 PM
came back from lunch and car sitting in warm building it started right up.
1988 Bronco 351 C6
Old 12-07-2005, 05:02 PM
I'm getting injector pulse, and good spark, I'm beginning to think its the crank position sensor.
"Having the same problem. It is 4 degrees here and when cranking over I have no injector pulse. Plugs are good and I have spark. I also have no power to the injectors."
When cranking, does your motor seems like it want to start but it can't?
Old 12-07-2005, 05:04 PM
Sounds like you need a fuel pump. If you have spark and injector pulse your crank sensor is working.
1988 Bronco 351 C6
Old 12-07-2005, 06:35 PM
Problem fixed. I located a new crankshaft position sensor. This is a 2.0L distributorless ignition motor. Part #39180-23500. The part # is also engraved in the sensor itself. This is the correct part for this particular engine/ecm. I purchased this other sensor part # 39180-23000. And the car crank but no start.
I replaced the crank position sensor because when its cold the car will start up and run fine. but as soon as i turn of the car(warmed-up). It will not start up at all. Until i remove the crank sensor and spray it down with brake cleaner and the car will start up again.
Old 09-15-2009, 07:02 AM
IBMaced IBMaced is offline
Re: 2000 Elantra
I have a similar problem and believe it is my crank shaft sensor. Can someone tell me where it is located on the engine. And if there are any tricks in replacing it?
Thank You
