Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 12-06-2005, 06:02 PM
Red Hot Mitsubishi Red Hot Mitsubishi is offline
Question fuse problem
recently i found that my stereo an dome ligths wasn't working, I found that the problem was a fuse, then I remplace it but is still hapening the same problem every time when i change que fuse, any idea?
Thanks
Old 12-06-2005, 06:51 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: fuse problem
there's probably a bad ground somewhere, make sure you go to a auto parts store and have them check your battery connection and alternator status just for kicks to see if anything could be wrong w/ that
if that doesn't help, the next step is to go to a mechanic...
Don't act like you don't love it.
503/2000
Old 12-07-2005, 07:25 AM
cficare68's Avatar
cficare68 cficare68 is offline
Re: fuse problem
Is it blowing the fuze or does a new fuze just not work.
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 12-07-2005, 08:00 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: fuse problem
did you recently replace your headunit with an aftermarket one?
Old 12-07-2005, 03:54 PM
fuse problem
it is blowing the fuze just in about 10 secs. after I put a new one.
Old 12-07-2005, 03:56 PM
fuse problem
I am still using the factory head unit.
Old 12-07-2005, 08:27 PM
Sleepr awd's Avatar
Re: fuse problem
...kinda curious as to what fuse your supposed to use...where are you getting the fuses from and what type of fuse are you using?
503/2000
Old 12-08-2005, 01:56 AM
fuse problem
I don't know about fuses but I just took the original to the autozone and they sold me a box whit 10 fuses but the number in the top says -10- then I try -15- but it is still blowing it up
Old 12-08-2005, 09:35 AM
Sleepr awd's Avatar
Re: fuse problem
unfortunately i'm no wiring expert but using a bigger fuse is the wrong thing to do, make sure it is the apporpriate fuse (check a manual) and if you still have problems take it to a mechanic
if you use a bigger fuse, it allows more electricity to get through which could cause a fire or for you to roast some wires, which is even worse, thats why houses have those fuse boxes
503/2000
Old 12-11-2005, 09:05 PM
rx7bsebal2oo6 rx7bsebal2oo6 is offline
Re: fuse problem
Hey also if anyone knows anything about the electrical my gas gauge isn't lighting up... Is it a fuse or something that needs to be replaced??
Old 12-11-2005, 09:29 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Re: fuse problem
The backlight is probably out. Not a hard fix if you know how to intstall aftermarket gauges. Find out the bulb type, and replace it...it should be fairly simple.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 12-11-2005, 10:18 PM
Re: fuse problem
I have no idea how to get my dash off to get to the gauges... I've had my after market gauges for ever and have no idea how to put them in...
Old 12-12-2005, 08:04 AM
cficare68's Avatar
Re: fuse problem
If it keeps blowing fuses you may have a short in a wire that is causing it to blow
Old 12-12-2005, 02:10 PM
Re: fuse problem
I need help getting my dash off to get to my gauges... anyone know the easier retard proof way of doing it?
Old 12-13-2005, 09:50 PM
Re: fuse problem
Nevermind... I got it... it took me long as hell because im retarded but the gauges are sick
